We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Discover the ground breaking 49-inch super ultra-wide Quantum Dot technology and VA panel with 1ms response time
The fast 144Hz screen refresh rate ensures you flawlessly smooth action scenes even in games with high frame rates. And you can adjust the refresh rate to 60Hz/120Hz when necessary
QLED supports High Dynamic Range (HDR) and Quantum Dot for images with a wider range of luminance levels that render dark areas deeper and light areas brighter
Multiple connections with 2 x HDMI, Displayport, Mini Displayport and 2 x USB 3.0, the CHG90 is ready to handle all of your devices
32:9 Super Wide Aspect Ratio - Equivalent to two 27" 16:9 monitors side by side, the 32:9 super ultra-wide screen provides the ultimate in multitasking flexibility
Product Description | Samsung C49HG90DMR - CHG9 Series - QLED monitor - curved - 49" - HDR | Device Type | QLED monitor - 49" | Energy Class | Class G | Energy Consumption per Year | 79 kWh | Power Consumption (On mode) | 54 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync Premium Pro | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 32:9 | Native Resolution | UWFHD 3840 x 1080 (DisplayPort: 144 Hz, HDMI: 120 Hz) | Brightness | 600 cd/m² | Contrast Ratio | 3000:1 | HDR Capable | DisplayHDR 600 | Response Time | 1 ms (MPRT) | Colour Support | 1.07 billion colours | Colour Gamut | 125% sRGB, 88% (CIE 1976), 92% Adobe RGB, 95% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 120.3 cm x 38.16 cm x 52.55 cm | Weight | 15 kg |
General | |
Display Type | QLED monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 49" |
Viewable Size | 48.9" |
Curved Screen | Yes (1800R) |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
HDR Certification | DisplayHDR 600 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, Cinema Mode, Mega Dynamic Contrast Ratio, Black eQualizer, FPS Mode, Flicker Free technology, RTS Mode, Eco Saving Plus, Eye Saver Mode, Factory Tunning, Low Input Lag, Quantum Dot Technology, Super Arena Gaming UX, Screen Size Optimizer, Refresh Rate Optimizer, Game Color Mode, Custom Key, RPG Mode, AOS Mode, sRGB Mode, USB charging port |
Colour | Black |
Dimensions (WxDxH) | 120.3 cm x 38.16 cm x 52.55 cm - with stand |
Weight | 15 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , Mini DisplayPort , 2 x HDMI , Audio line-in , Headphones , 2 x USB 3.0 , Audio line-in |
Mechanical | |
Tilt Angle | -2/+15 |
Swivel Angle | 30 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 54 kWh/1000h |
Power Consumption HDR (On mode) | 78 kWh/1000h |
Power Consumption (Typical) | 54 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Easy Setting Box |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 120.3 cm - depth: 38.16 cm - height: 52.55 cm - weight: 15 kg , Without stand - width: 120.3 cm - depth: 19.44 cm - height: 36.94 cm - weight: 11.9 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 132 cm |
Shipping Depth | 47.6 cm |
Shipping Height | 31.6 cm |
Shipping Weight | 20.7 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
