Designed for gamers, IT admins and creative professionals, the Samsung 860 PRO is powered by V-NAND technology and a robust algorithm-based Samsung controller to handle the heavy workloads of high-end client PCs, workstations and NAS. Get fast, enduring performance with exceptional reliability and expanded compatibility.
Product Description | Samsung 860 PRO MZ-76P4T0B - solid state drive - 4 TB - SATA 6Gb/s | Type | Solid state drive - internal - TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache | Capacity | 4 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | 3D multi-level cell (MLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 4 GB | Features | TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667 | Dimensions (WxDxH) | 6.985 cm x 10 cm x 0.68 cm | Weight | 62 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 4 TB |
Width | 6.985 cm |
Depth | 10 cm |
Height | 0.68 cm |
Weight | 62 g |
Performance | |
SSD Endurance | 4800 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 560 MBps (read) / 530 MBps (write) |
4KB Random Read | 11000 IOPS |
4KB Random Write | 43000 IOPS |
Maximum 4KB Random Write | 90000 IOPS |
Maximum 4KB Random Read | 100000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 2.2 Watt (average) , 4.5 Watt (maximum) |
Software & System Requirements | |
Software Included | Samsung Magician Software |
Miscellaneous | |
Compliant Standards | WWN, IEEE 1667 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
