The latest model of the world's best-selling SSD series has finally arrived. The 870 EVO inherits the legacy of Samsung's pioneering SSD technology, boasting upgraded performance, reliability and compatibility to suit the needs of anyone from content creators and IT professionals to everyday users.
Product Description | Samsung 870 EVO MZ-77E4T0B - SSD - 4 TB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 4 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | 3D multi-level cell (MLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 4 GB | Features | TRIM support, sleep mode, Auto Garbage Collection Algorithm, Worldwide Name (WWN), TurboWrite Technology, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667 | Dimensions (WxDxH) | 69.85 mm x 100 mm x 6.8 mm | Weight | 45 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 4 TB |
Width | 69.85 mm |
Depth | 100 mm |
Height | 6.8 mm |
Weight | 45 g |
Performance | |
SSD Endurance | 2400 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 560 MBps (read) / 530 MBps (write) |
4KB Random Read | 13000 IOPS |
4KB Random Write | 36000 IOPS |
Maximum 4KB Random Write | 88000 IOPS |
Maximum 4KB Random Read | 98000 IOPS |
Reliability | |
MTBF | 1,500,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 5 Watt (average) , 5 Watt (maximum) |
Software & System Requirements | |
Software Included | Samsung Magician Software |
Miscellaneous | |
Compliant Standards | WWN, IEEE 1667 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
