Samsung 55" 5 Series LED 1080p Full HD TV Black
Key features
  • Fit seamlessly into your chosen space
  • Tailor your TV to your lifestyle
  • Remove the need for multiple messy wires and vents
  • Access all of your content quickly and easily
Product codes
  • Full HD 1080p
  • Tuner: Freeview HD
  • Connectivity: HDMI x 2
  • Sophisticated Joiiii design with adjustable legs
  • Quality speakers for crisp sound
  • True to life imagery with wide colour enhancer
Designed to enhance your living room, the UE55K5100 has a contemporary look with angled, adjustable legs and a slim bezel.
Quality speakers
Featuring front firing speakers with tweeters for crisp and clear sound – the TV sounds great no matter what you watch. Designed to adapt to your needs, the K5100 also lets you switch to crisper, more audible sound – perfect for helping an older member of family.
Enjoy crisp and clear picture quality with Full HD 1080p resolution, which uses an advanced picture algorithm for improved detail. Uncovering hidden details and allowing you to see colours as they were meant to be, Samsung's wide colour enhancer makes every film and TV show look great.
Product Description Samsung UE55K5100AK 5 Series - 55" LED TV
Product Type LED-backlit LCD TV
Diagonal Class 55"
Colour Indigo black
Resolution 1920 x 1080
Display Format 1080p (Full HD)
Motion Enhancement Technology 200 Picture Quality Index, 50 Motion Rate
Video Interface Component, composite, HDMI
HDMI Ports Qty 2 ports
Connectivity Wi-Fi (optional)
LCD Backlight Technology LED backlight
Image Aspect Ratio 16:9
TV Tuner 1x analogue, 1x digital
Digital TV Tuner DVB-C, DVB-T2
Multi-channel Preview Picture-in-picture (PIP)
Speaker System 2 speakers
USB Yes
Remote Control Standard remote
Voltage AC 230V (50/60 Hz)
Energy Class Class A
Power Consumption Operational 118 Watt
Power Consumption (On mode) 87 W
Energy Consumption per Year 127 kWh
Dimensions (WxDxH) - without stand 123.26 cm x 9.8 cm x 75.25 cm
Weight 15.6 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 55" 5 Series L...
