Samsung 64GB Duo Plus USB 3.1 Drive - Up to 200MB/s
£22.94
Select:
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Either way is the right way
  • Double your connectivity
  • Tough & trusted
  • Capacity: 64GB
  • Interface: USB 3.1 / USB-C
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Double up on convenience. The DUO Plus is a Type-C drive with a super-useful Type-A adapter. Eliminate worries as the intuitive integrated Type-A adapter works with your older devices. You can flexibly move data and free up space with superior speed and performance.
Product Description Samsung DUO Plus MUF-64DB - USB flash drive - 64 GB
Product Type USB flash drive
Interface Type USB 3.1 / USB-C
Storage Capacity 64 GB
Manufacturer Warranty 5-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: DRNY 043031
£17.79
product
Ref: DRNY 043031
Accessories
Packaging
Functional
Software
Manuals
£17.79
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 64GB Duo Plus...
£22.94
