Samsung 860 DCT 1.9TB SATA 6Gb/s 2.5" SSD Hard Drive
£329.70
Delivery:
Standard: 1-3 working days
Key features
  • Designed for optimized performance and value in read-intensive enterprise applications thanks to Samsung's proprietary 3-bit MLC V-NAND
  • Delivers enhanced efficiency for operations and maintenance thanks to low power consumption
  • Reliable solid state drive with the endurance to handle heavy workloads for servers
  • Form Factor: 2.5"
  • Capacity: 1.9TB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Samsung's 860DCT SSDs deliver optimized performance and value for read-intensive applications like servers and data centers. They feature Samsung's proprietary V-NAND technology and are built from Samsung components for a high-density, reliable enterprise storage solution with low power consumption, strong data security and proactive monitoring.
Product Description Samsung 860 DCT MZ-76E1T9E - solid state drive - 1.9 TB - SATA 6Gb/s
Type Solid state drive - internal - Auto Garbage Collection Algorithm, Samsung MJX Controller
Capacity 1.9 TB
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features Auto Garbage Collection Algorithm, Samsung MJX Controller, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100 mm x 6.8 mm
Weight 60 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 860 DCT 1.9TB...
£329.70
