Samsung 960GB 983DCT M.2 NVMe SSD
£237.33
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • M.2 form factor and NVMe (Non-Volatile Memory Express) interface deliver blazing fast speed
  • End-to-end data protection to help ensure consistency over the entire data transfer path
  • Power-loss protection helps to prevent data corruption in the case of power failure
  • Designed for optimized performance in server applications thanks to Samsung's proprietary 3-bit MLC V-NAND
  • Stock Status: In Stock
Product codes
Samsung's 983 DCT is a high-performance solution for servers that need enhanced data reliability to safeguard critical data, from content delivery networks (CDNs) to big data, artificial intelligence (AI) and Internet of Things (IoT) applications. Available in two form factors, U.2 and M.2., the 983 DCT's NVMe interface empowers blazing-fast speed, high responsiveness and a high Quality of Service (QoS).
Product Description Samsung 983 DCT MZ-1LB960NE - solid state drive - 960 GB - PCI Express 3.0 x4 (NVMe)
Type Solid state drive - internal - TRIM support, Auto Garbage Collection Algorithm, Enterprise Power-Loss Protection, Advanced ECC Engine, Samsung Phoenix Controller
Capacity 960 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor M.2 22110
Interface PCI Express 3.0 x4 (NVMe)
Buffer Size 1.5 GB
Features TRIM support, Auto Garbage Collection Algorithm, Enterprise Power-Loss Protection, Advanced ECC Engine, Samsung Phoenix Controller, S.M.A.R.T.
Dimensions (WxDxH) 22 mm x 110.02 mm x 3.8 mm
Weight 20 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 960GB 983DCT M...
£237.33
