Marketing description is not available.
Product Description | Samsung C27H580FDU - CH58 Series - LED monitor - curved - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Energy Consumption per Year | 51 kWh | Power Consumption (On mode) | 35 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Colour | Blue black | Dimensions (WxDxH) - with stand | 61.42 cm x 27.04 cm x 45.73 cm | Weight | 4.2 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Viewable Size | 27" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Safe, Image Size, Eco Saving Plus, Eye Saver Mode, Active Crystal Color, 119.3% sRGB colour gamut, 88.4% Adobe RGB colour gamut, 80.6% (CIE 1976) colour gamut |
Dimensions (WxDxH) | 61.42 cm x 27.04 cm x 45.73 cm - with stand |
Weight | 4.2 kg |
Connectivity | |
Interfaces | HDMI , VGA , DisplayPort , Headphones , Audio line-in |
Mechanical | |
Tilt Angle | -2/+20 |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 35 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.42 cm - depth: 27.04 cm - height: 45.73 cm - weight: 4.2 kg , Without stand - width: 61.42 cm - depth: 14.29 cm - height: 26.29 cm - weight: 3.3 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
