Samsung C34H890WJU 34" 3440x1440 4ms HDMI DP USB-C LED M...
Samsung C34H890WJU 34" 3440x1440 4ms HDMI DP USB-C LED Monitor
£628.32
46 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enhanced visual clarity with Ultra WQHD resolution (3440 x 1440)
  • Perfect multi-tasking with a 21:9 wide screen, PBP and easy setting box S/W
  • Greater viewing comfort with industry-leading 1800R curvature
  • More convenient connectivity with a USB type C
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
The CH89 has a screen resolution of 3440 x 1440 - approximately 2.5 times the pixel density of Full HD - that delivers razor-sharp images. You can see more details at a glance and have a panoptic view of large web pages and documents with less scrolling and zooming.
The 34" ultra-wide curved monitor CH89 is ideal for multi-taskers who need more on-screen space for their big ideas but want to do away with the hassle of dual-monitor setups. With its ultra-wide display you can experience truly seamless single-monitor multitasking.
Samsung's Picture-by- Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality.
Product Description Samsung C34H890WJU - CH890 Series - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class B
Energy Consumption per Year 83 kWh
Power Consumption (On mode) 57 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Panel Type VA
Aspect Ratio 21:9
Native Resolution 3440 x 1440 at 100 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Colour Dark silver
Environmental Standards TCO Certified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung C34H890WJU 34"...
£628.32
