Samsung C34J791WTU 34" 3440x1440 4ms HDMI LED Monitor
£749.48
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect compatible Macs and PCs with two Thunderbolt 3 ports
  • Greater viewing comfort with curved screen
  • Perfect multi-tasking with 21:9 wide screen, PBP and PIP
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, Thunderbolt 3
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £878.48
Save £30.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £752.97
Save £1.50
SAMSUNG GALAXY BUDS - BLACK
= £863.48
The CJ79 features two Thunderbolt 3 ports to connect compatible Macs and PCs. Thunderbolt 3 transmits video and data at speeds of up to 40 Gbps and simultaneously charges devices (up to 85 W), all over a single cable. The curved screen is engineered to follow the natural curve of your eyes for a more immersive and comfortable viewing experience.
Product Description Samsung C34J791WTU - CJ79 Series - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class C
Energy Consumption per Year 95 kWh
Power Consumption (On mode) 65 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type VA
Aspect Ratio 21:9
Native Resolution Ultra WQHD 3440 x 1440 at 100 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xThunderbolt 3, HDMI, DisplayPort
Display Position Adjustments Height, tilt
Colour Grey
Dimensions (WxDxH) - with stand 80.87 cm x 30.94 cm x 51.6 cm
Weight 7.7 kg
Compliant Standards DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung C34J791WTU 34"...
£749.48
