Samsung C49J890DKU 49" 3840x1080 4ms HDMI DP USB-C Curve...
Samsung C49J890DKU 49" 3840x1080 4ms HDMI DP USB-C Curved LED Monitor
£862.39
Delivery:
  • Diagonal Size: 49in
  • Max Resolution: 3840 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Work Wider. Work Smarter.
With a feature set as impressive as its 49" super ultra-wide curved screen, Samsung’s revolutionary CJ89 monitor is designed to improve performance in any workplace. So whatever your task, enjoy working smarter with Samsung.
Product Description Samsung C49J890DKU - CJ89 Series - LED monitor - curved - 49"
Device Type LED-backlit LCD monitor - 49"
Energy Class Class B
Energy Consumption per Year 91 kWh
Power Consumption (On mode) 62 W
Curved Screen Yes
Features KVM Switch, USB 3.0/USB-C hub
Panel Type VA
Aspect Ratio 32:9
Native Resolution 3840 x 1080 at 144 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Colour Charcoal black
Dimensions (WxDxH) - with stand 120.3 cm x 38.16 cm x 52.55 cm
Weight 15.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung C49J890DKU 49"...
£862.39
