Samsung CF79 Series C34F791WQU 34" 3440x1440 4ms HDMI Di...
Samsung CF79 Series C34F791WQU 34" 3440x1440 4ms HDMI DisplayPort LED Curved Monitor
£728.19
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Curved like your eyes for great viewing comfort
  • Ultra WQHD for incredible image detail and a wider workspace
  • More accurate and life-like colors with Quantum Dot Technology
  • Excellent 3000:1 contrast ratio and minimal light leakage
  • Flawless game play
  • Unparalleled sophisticated design
  • Built-in speakers and multiple ports for all your entertainment needs
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
Samsung CF79 Series C34F791WQU 34" 3440x1440 4ms HDMI...
£728.19
= £741.19
Save £3.00
    Samsung's 1500R curved screen with the deep curvature is precision engineered to match the natural curvature of your eyes more closely than any other monitor. The deeper curve resulted in reduced eyestrain among viewers compared to flat-screens or other less curved monitors. With Samsung Flicker Free technology and Eye Saver Mode reducing fatigue-inducing blue light emissions, you simply can't get a more comfortable viewing experience.
    Ultra WQHD enables a screen resolution of 3440 x 1440 - 2.5 times the pixel density of Full HD - that delivers razor-sharp images. The greater pixel density also creates a wider screen workspace, so you see more content at once without much effort scrolling and zooming when web surfing or viewing large files such as spreadsheets.
    Supporting up to 125% sRGB color space, Quantum Dot technology delivers not only more colors than conventional monitors but also colors that are brighter, crisper, and more natural - particularly reds and greens. And because every monitor is factory calibrated, you can be sure you always see the most accurate and life-like images.
    Samsung's advanced VA panel technology minimizes light leakage across the entire screen - right up to the corners - and delivers an excellent 3000:1 contrast ratio for deep blacks.
    Packed with features to satisfy the most dedicated gamers, this premium curved monitor boasts a 100 Hz screen refresh rate for minimal stutter, a 4 ms response time for blur-free action scenes, and AMD Freesync for silky smooth gameplay. And with Game Mode letting you instantly optimize screen brightness and contrast ratios, you'll also enjoy spotting your enemies faster in any kind of game.
    Effortlessly combining function and style, the ultrawide curved screen is bezeless on three sides enhancing its classy figure and seamless viewing. The glossy white rear casing, curving horizontally and vertically, incorporates a hatch to keep cables neatly stowed. And the anti-glare panel is supported on functional swing-and- tilt height adjustable stand that allows precise positioning for enhanced viewing comfort.
    Dual speakers embedded into the display let you enjoy movies, games, and online content without cluttering your desktop with auxiliary speakers or cables. And 2 HDMI, DP, and 2 USB ports provide a high-performance multiple connection interface that lets you hook up PCs, game consoles, additional monitors, and other devices with ease.
Forget about the inconvenience of dual monitors - with the 21:9 ultrawide monitor you can experience truly seamless multitasking on a single screen. For total flexibility, Samsung's Picture-by-Picture (PBP) function lets you connect two input sources using HDMI and DP while maintaining the original image quality.
Samsung CF79 Series C34F791WQU - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
102 kWh
Power Consumption (On mode)
70 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Grey
80.87 cm x 30.94 cm x 51.6 cm
7.6 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung CF79 Series C3...
£728.19
