Samsung CF79 Series C34F791WQU 34" 3440x1440 4ms HDMI Di...
£728.19
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Curved like your eyes for great viewing comfort
  • Ultra WQHD for incredible image detail and a wider workspace
  • More accurate and life-like colors with Quantum Dot Technology
  • Excellent 3000:1 contrast ratio and minimal light leakage
  • Flawless game play
  • Unparalleled sophisticated design
  • Built-in speakers and multiple ports for all your entertainment needs
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Forget about the inconvenience of dual monitors - with the 21:9 ultrawide monitor you can experience truly seamless multitasking on a single screen. For total flexibility, Samsung's Picture-by-Picture (PBP) function lets you connect two input sources using HDMI and DP while maintaining the original image quality.
Product Description Samsung C34F791WQU - CF79 Series - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class C
Energy Consumption per Year 102 kWh
Power Consumption (On mode) 70 W
Curved Screen Yes
Features USB 3.0 hub
Panel Type VA
Aspect Ratio 21:9
Native Resolution 3440 x 1440 at 100 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height
Colour White
Dimensions (WxDxH) - with stand 80.87 cm x 30.94 cm x 51.6 cm
Weight 7.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung CF79 Series C3...
£728.19
