Forget about the inconvenience of dual monitors - with the 21:9 ultrawide monitor you can experience truly seamless multitasking on a single screen. For total flexibility, Samsung's Picture-by-Picture (PBP) function lets you connect two input sources using HDMI and DP while maintaining the original image quality.
Product Description | Samsung C34F791WQU - CF79 Series - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class C | Energy Consumption per Year | 102 kWh | Power Consumption (On mode) | 70 W | Curved Screen | Yes | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 21:9 | Native Resolution | 3440 x 1440 at 100 Hz | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height | Colour | White | Dimensions (WxDxH) - with stand | 80.87 cm x 30.94 cm x 51.6 cm | Weight | 7.6 kg | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Curved Screen | Yes (1500R) |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, picture by picture, Flicker Free technology, Eye Saver Mode, FreeSync Technology, Quantum Dot Technology, 125% sRGB colour gamut |
Colour | White |
Dimensions (WxDxH) | 80.87 cm x 30.94 cm x 51.6 cm - with stand |
Weight | 7.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones |
Mechanical | |
Height Adjustment | 100 mm |
VESA Mounting Interface | Yes |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Power | |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 80.87 cm - depth: 80.87 cm - height: 51.6 cm - weight: 7.6 kg , Without stand - width: 80.87 cm - depth: 16.7 cm - height: 36.28 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
