Samsung CHG90 49" Curved HDR QLED Gaming Monitor
£879.48
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • HDR changes the game
  • Built for speed
  • Smoother gameplay
  • Play for longer
  • Seamless multitasking
  • Diagonal Size: 49in
  • Max Resolution: 3840 x 1080
  • Response Time: 1ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £1,008.48
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £993.48
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £882.97
Save £1.50
Discover the ground-breaking 49-inch super ultra-wide curved monitor from Samsung, with 32:9 aspect ratio. Giving you a more comfortable viewing experience and more realistic colours with Quantum dot and HDR technology. The CHG90 49" monitor make working in the office easy with powerful multi-tasking with picture-by-picture and easy setting software.
Display more of your documents
With its 32:9 aspect ratio the 49" super ultra-wide curved panel provides all the space you need to display more of your data-rich documents. The CHG90 offers a view so panoramic that you can keep many windows open at once and work comfortably with less scrolling and zooming.
Display more documents
No more dual-monitor inconvenience
Equivalent to two 27" monitors side by side, the super ultra-wide panel eliminates the need for traditional dual monitor setups with mismatched screens, awkward bezel breaks and multiple cables cluttering your office space. With the CHG90 QLED monitor, you can do it all on a single monitor.
Dual monitor inconvenience
More lifelike color
HDR and Samsung’s advanced QLED technology are capable of producing more realistic color than conventional monitor technologies. Which means that whatever the task in front of you, you can be sure the colors you see onscreen are truer to those around you.
More lifelike colour
Maximum multitasking efficiency
The Picture-by-Picture function simultaneously displays input from different devices without losing any of the original image quality. You can simply hook up your Galaxy S8/S8+with the Samsung DEX Station to manage all your mobile content alongside other onscreen projects.
Work smarter with Easy setting box Soft Ware
With its intuitive interface and options designed for maximum efficiency, Easy Setting Box Soft Ware lets you quickly and easily partition the screen or display multiple screens of various sizes in a variety of configurations. Multitask smarter with Easy setting box.
Work smarter
PIP + DeX Station
Letting you resize a second image up to 25% of the screen and position it anywhere you want, Picture-in-Picture makes multitasking simple whatever you are working on. And connect the DeX Station to keep any eye on all your mobile calls, messages and more.
PIP and Dex
Ideal for long hours of work
Engineered to match the natural curvature of your eyes, the ergonomic 1800R curved panel offers enhanced viewing comfort compared to traditional flat screens. And Samsung’s Flicker Free technology and blue light-reducing Eye Saver Mode minimize eye fatigue when working for extended periods.
Enhanced speed and fine control
The superfast response time, 144hz screen refresh rate, and AMD freeSync maximize productivity when working with photo and video files, ensure smoother display and playback, and provide fine cursor control for accuracy. With the CHG90, you can handle even the most demanding tasks with ease.
Enhanced speed and control
Increase your ergonomic efficiency
It swivels, tilts, and is height-adjustable, compatible with VESA-standard monitor arms. With these functions at your disposal, you can effortlessly position your screen at whatever height and angle you want and share the onscreen content with nearby coworkers.
Increased ergonomic efficiency
Multiple input ports that connect to any device
Featuring DP, Mini-DP and multiple HDMI and USB ports, the CHG90 lets you connect almost any device you can imagine with minimum fuss. So, whatever device you, your colleagues, or your clients choose to use, you can always rely on the CHG90.
Multiple ports
Product Description Samsung C49HG90DMU - CHG9 Series - QLED monitor - curved - 49"
Device Type QLED monitor - 49"
Energy Class Class B
Energy Consumption per Year 104 kWh
Power Consumption (On mode) 71 W
Curved Screen Yes
Features USB 3.0 hub
Panel Type VA
Aspect Ratio 32:9
Native Resolution 3840 x 1080 at 144 Hz
Brightness 600 cd/m²
Response Time 1 ms
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, swivel, tilt
Colour Black coal
Dimensions (WxDxH) - with stand 120.3 cm x 38.16 cm x 52.55 cm
Weight 15 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung CHG90 49" Curv...
£879.48
