Samsung CLX8380ND CYAN TONER
Key features
  • Unique toner design - SAMSUNG printer cartridges are the smallest and lightest in their class, ideal for personal, small or home office users.
  • NO-NIOS™ - Imagine a printer that operates quietly and allows you to concentrate on other important tasks while it prints. The NO-NOIS™ engine design means the toner is stored in a fixed cartridge mechanism, eliminating noise and vibration. It also simplifies toner changes - there are no heavy toners to change, just small, easy-to-access toner bottles.
  • Genuine Quality - Enjoy consistent print results .With SAMSUNG supplies you're virtually guaranteed high quality pages without any defects.
  • Security label - SAMSUNG supplies include a color-changing security label that proves they are genuine products. When the label is tilted, the color changes from clear to cyan. Plus, the embossed characters change between red gold and blue when seen from different angles. You can also verify its originality by feeling its texture.
  • easy-to-change toner - No mess. No fuss. SAMSUNG printer cartridges are easy to replace so you can get back to work. Simply follow three easy steps: open the front cabinet, change the cartridge, and close the cabinet. That's all there is to it!
  • Standardized cartridge - Each SAMSUNG LaserJet cartridge has been tested to meet ISO (International Organization for Standardization) standards, which makes it easy to compare toner yields from different manufacturers. With SAMSUNG toner cartridges, you can be confident that you're making an informed buying decision.
  • Automatic toner monitoring system - Never get stuck on empty again. When toner is running low, the automatic toner monitoring system conveniently notifies you.
Product codes
SAMSUNG Color Laser Supplies are designed to maximize the machine performance. Constantly redesigned and improved SAMSUNG Supplies provide best performance, reliability and outstanding color printing quality. SAMSUNG Color Laser Toner cartridges have stable & professional image quality in high-speed and high volume printings. High capacity color toner cartridges make it easy to produce brilliant & cost effective color documents and increase uptime. Uniformly pulverized toner produces gloss uniformity, crisp print and consistent high image quality.
Product Description Samsung CLX-C8380A - cyan - original - toner cartridge
Product Type Toner cartridge
Printing Technology Laser
Printing Colour Cyan
Yield Up to 15000 pages
Compatible with MultiXpress 8380ND
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung CLX8380ND CYAN...
