Presenting a stylish business monitor that suits both your vision and your budget. Series 20 monitors have a sleek design plus a high dynamic contrast ratio and fast response time, along with exclusive Magic technologies, to enhance your productivity. No matter how you look at it, the outlook is bright with Samsung Series 20 monitors.
| Product Description | Samsung SyncMaster E2220 - LCD monitor - Full HD (1080p) - 21.5" | Device Type | LCD monitor - 21.5" | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 70000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Colour | Black | Dimensions (WxDxH) | 51.3 cm x 20 cm x 38.9 cm | Weight | 4.1 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Compliant Standards | DDC-2B |
General | |
| Display Type | LCD monitor / TFT active matrix |
| Diagonal Size | 21.5" |
| Horizontal Viewing Angle | 170 |
| Vertical Viewing Angle | 160 |
| Controls & Adjustments | H/V position, tilt |
| Features | Power off timer, HDCP, MagicAngle, MagicReturn, MagicEco, MagicBright 3 |
| Colour | Black |
| Weight | 4.1 kg |
Connectivity | |
| Interfaces | VGA , DVI-D |
Mechanical | |
| VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
| Features | Wall mountable |
| Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
| Power Supply | Internal |
| Power Consumption (Typical) | 45 Watt |
| Power Consumption Stand by / Sleep | 0.3 Watt |
Dimensions & Weight (Shipping) | |
| Shipping Width | 58.6 cm |
| Shipping Depth | 13.6 cm |
| Shipping Height | 38.6 cm |
| Shipping Weight | 5.3 kg |
Environmental Standards | |
| EPEAT Compliant | EPEAT Silver |
| ENERGY STAR Certified | Yes |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
