Samsung Fast In/Out Battery Pack 5,100mAh - Grey
Key features
  • Huge capacity
  • Easy to hold with built in carrying strap
Product codes
The Samsung Fast Charge Portable Battery gives you additional charges to your smartphone. With Samsung Fast Charge, compatible devices can charge faster than standard USB charging options. You can charge your battery and phone at the same time with pass-through charging. Connect your phone to the portable battery, and then begin charging the battery. An LED power indicator shows just how much power is left in your portable battery.
Samsung Fast Charge Portable Battery Pack EB-PG950 - power bank
Power bank
7.42 cm x 1.38 cm x 13.23 cm
151.3 g
Grey
Output Connector Type
USB - on cable: Micro-USB
5 - 9 V
Voltage Provided
5 - 9 V
Fast Charge Technology
Samsung Fast Charge
- 5100 mAh
Cables
Micro-USB to USB cable - 20 cm , Micro-USB to USB-C adapter
Galaxy A8 (2018) Enterprise Edition, Note8, S8, S8 Active, S8+
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Fast In/Out Ba...
