We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Pure processing power
Time to get to work. Powered with a 5nm Octa-core processor, your Galaxy is built to handle heavy-duty multitasking. RAM Plus reads your usage patterns and provides extra virtual RAM for an additional boost.
Hold on to your memories
With 128GB of internal storage plus support for a microSD card up to 1TB, you've got a whole lot of room for all your precious moments.
A cinematic view of your world
Feast your eyes on vibrant details with the FHD+ Super AMOLED display. With the expansive 6.5-inch Infinity-O Display, enjoy vivid outdoor visibility up to 800 nits while reducing blue light with the Eye Comfort Shield.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy A53 5G - awesome white - 5G smartphone - 128 GB - GSM | Product Type | 5G smartphone | Manufacturer Model Number | SM-A536B/DS | Display | OLED display - 2400 x 1080 pixels - 6.5" - (120 Hz) - Super AMOLED - Corning Gorilla Glass 5 (scratch resistant glass) | Processor | 2.4 GHz (8-core) | Memory | RAM 6 GB / 128 GB | Supported Memory Card | microSDXC slot - up to 1 TB | Operating System | Android 12 with One UI 4.1 | Main Camera | 64 Megapixel - f/1.8 - focus: automatic | Second Camera | 12 Megapixel - ultra wide-angle lens - f/2.2 | Third Camera | 5 Megapixel - f/2.4 - macro camera | Fourth Camera | 5 Megapixel - f/2.4 - depth camera | Front Camera | 32 Megapixel f/2.2 - focus free | Service Provider | Not specified | SIM Card | Dual-SIM - nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth | Security Devices | Fingerprint reader (under display) | Connectors | USB-C | Talk Time | Up to 2520 minutes | Protection | Water-resistant, dust-resistant | Colour | Awesome white | Dimensions (WxDxH) | 74.8 mm x 8.1 mm x 159.6 mm | Weight | 189 g | Repairability Index | 8.2 (out of 10) | SAR | 1.597 W/kg (body), 2.87 W/kg (limb), 0.885 W/kg (head) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 74.8 mm |
Depth | 8.1 mm |
Height | 159.6 mm |
Weight | 189 g |
Body Colour | Awesome white |
SAR Value | 1.597 W/kg (body), 2.87 W/kg (limb), 0.885 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 5G |
Operating System | Android 12 |
User Interface | One UI 4.1 |
Navigation | GPS, GLONASS, BeiDou, Galileo, QZSS |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM |
SIM Card Configuration Details | Nano SIM + nano SIM/microSD |
Input Device | Multi-touch |
Communications | |
Data Transmission | FDD-LTE, TDD-LTE, 5G NR FR1 |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 2, Band 4, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 1700, 850, 900 |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3 |
5G NR Band | N1, n3, n7, n8, n20, n28, n38, n41, n78, n40 |
5G NR Frequency | FDD 2100, FDD 1800, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, TDD TD 3500, TDD 2300 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.1 |
Phone Features | |
Sensors | Accelerometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor |
Additional Features | Power Saving Mode, Fast Charging, Samsung KNOX, Game Booster, Secure Folder function, Samsung Smart Switch, Virtual Proximity Sensing, dual stereo speakers |
Media Player | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID |
Supported Digital Video Standards | MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4 |
Sound Enhancements | Dolby Atmos sound technology |
Processor | |
Clock Speed | 2.4 GHz |
Processor Core Qty | 8-core |
Memory | |
RAM | 6 GB |
Internal Memory Capacity | 128 GB |
User Memory | 101 GB |
Supported Flash Memory Cards | microSDHC, microSD, microSDXC - up to 1 TB |
Front Camera | |
Sensor Resolution | 32 Megapixel |
Lens Aperture | F/2.2 |
Focus Adjustment | Focus free |
Special Effects | Bokeh effect |
Main Camera | |
Sensor Resolution | 64 Megapixel |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Lens Aperture | F/1.8 |
Focus Adjustment | Automatic |
Digital Zoom | 10x |
Camera Modes | Fun mode, portrait mode |
Light Source | Flash |
Video Resolutions | Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps |
Features | vDIS technology, AI image enhancer |
Second Camera | |
Sensor Resolution | 12 Megapixel |
Lens Type | Ultra wide-angle lens |
Third Camera | |
Sensor Resolution | 5 Megapixel |
Lens Aperture | F/2.4 |
Functions | Macro camera |
Fourth Camera | |
Functions | Depth camera |
Display | |
Type | OLED display |
Technology | Super AMOLED |
Diagonal Size | 6.5" |
Display Resolution | 2400 x 1080 pixels |
Display Format | Full HD+ |
Max Brightness | 800 cd/m² |
Colour Depth | 16.7 million colours |
Enhancement Technology | Eye Comfort Shield |
Refresh Rate | 120 Hz |
Protection | Corning Gorilla Glass 5 (scratch resistant glass) |
Features | Infinity O display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C |
Battery | |
Capacity | 5000 mAh |
Fast Charging Technology | Samsung Super Fast Charging |
Talk Time | 2520 minutes |
Run Time Details | Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 18 hrs , Playback (wireless video): up to 18 hrs , Playback (wireless audio): up to 60 hrs , Talk (4G): up to 2520 min , Mixed usage: up to 48 hrs |
Miscellaneous | |
Compliant Standards | IP67 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Sustainability Information | |
Environmental Parameters | |
Max Depth of Water Resistance | 1 m |
