Samsung Galaxy A80 - Black
FREE DELIVERY
£299.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Capture the world as you see it
  • Enjoy immersive multimedia experiences
  • Stay connected for longer
  • Access what you need, when you need it - safely and securely
  • Express your style with an elegant design
  • EE Unlocked
  • Operating system: Android
  • Model: A80
  • Screen Size: 6.7in
  • Rear Camera: 48 Megapixel
  • Mobile Connectivity: 4G
Product codes
Bundle deals (4)
SAMSUNG GALAXY BUDS+
= £428.00
Save £30.00
JUICE 2M USB-C CABLE
= £305.98
Save £8.00
SAMSUNG GALAXY BUDS - BLACK
= £413.00
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £302.49
Save £1.50
This is a brand new Samsung Galaxy A80 Black (SM-A805F). This device was originally locked to the EE network, but has now been unlocked to work with other UK networks. The device will come pre-loaded with the MyEE and BT Sport apps, but these can be removed from the device if not needed.
Rotating Camera. Equally epic both sides.
The Galaxy A80 changes how you document life. The triple camera slides and rotates to catch what's happening in front and behind. Therefore, now you have one camera that shoots on both sides to capture all your moments. The camera built for Live. Not just for selfies.
Capture more detail in your stories
The Galaxy A80's 48MP camera gives you super crisp, clear resolution for shot-worthy moments. You'll notice the difference when vlogging and streaming your day-to-day adventures.
The camera that lets you see more
With its incredible 123-degree field of vision, our Ultra Wide Camera is built to capture as wide as the human eye can see, Live. So as things happen you can see and share more.
The display designed for Live
The maximised new Infinity Display is near bezel-less with no notches and no distractions. Its 6.7" Full HD+ Super AMOLED offers a big and bright canvas to explore content, stories, connections and creativity. The display built for Live. More room to play.
The battery that keeps you Live
To stay Live in an always-on world, you need power. Connect, stream and share with a 3,700 mAh (typical) battery and the 25W Super Fast Charging technology that lives to tell the tale. The Galaxy A80 learns your daily routines and usage patterns while optimising power by closing unused apps.
Share, stream and play faster
Galaxy A80 is the phone that's up for the challenge. The Intelligent Performance Enhancer recognises your mobile habits and optimises the powerful Octa-Core Processor and 8GB of RAM, so you can stream, game and use your phone with incredibly high performance.
Tap and go with your fingerprint
Our On-Screen Fingerprint is fused into the glass right where you need it, tap and go. Rest assured, your data is fully secure, and you’ll have access to your phone when you need it. The smartphone built for Live, to give you peace-of-mind.
EE unlocked
We have not tested that this device will work across every UK network operator.
There is no requirement for you to use this device on the BT/EE network.
Product Description Samsung Galaxy A80 - phantom black - 4G - 128 GB - GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-A805F/DS
Display OLED display - 2400 x 1080 pixels - 6.7" - 393 ppi - Super AMOLED
Features Digital player, triple rear-facing camera, 3D depth sensors camera
Processor 2.2 GHz (8-core)
Memory 128 GB RAM 8 GB
Operating System Android 9.0 Pie
Rear Camera 48 Megapixel - wide-angle lens - f/2.0 - focus: automatic - slide and rotate
Second Rear Camera 8 Megapixel - ultra wide-angle lens - f/2.2
Third Rear Camera - f/1.2 - 3D depth camera
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Dual-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices Fingerprint reader (under display)
Messaging Services SMS, MMS
Connectors USB-C
Talk Time Up to 1800 minutes
Colour Phantom black
Dimensions (WxDxH) 76.5 mm x 9.3 mm x 165.2 mm
Weight 220 g
SAR 1.43 W/kg (body), 0.22 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy A80 - B...
£299.00
