A new chapter for the PC!
Reliable performance
Have your workflow running smoothly and efficiently without interruption. Engineered with the 7th Gen Intel® Core™ processor, Windows 10 and an In-box Island Type Keyboard, the Galaxy Book has all the performance you need to keep you multitasking on the move.
Supremely vivid
Whether you’re working on a presentation or watching that new series, all your content is brought to life on screen, brilliantly. Choose either a bright and crisp 12" sAMOLED display* or 10.6" FHD TFT display. And on the Galaxy Book 12" you can fully immerse yourself in HDR videos with stunning detail and true-to-life colours.
Streamlined for mobility
With eye-catching dimensions made perfect for carrying your life on the go the Galaxy Book defies convention. Its slim, lightweight and portable design makes it the ultimate content companion for wherever your creativity may lead you.
Optimise your workflow
With adjustable angles, the Galaxy Book has unbeatable versatility to work the way you like. Boost your typing capabilities and make everything from drawing and sketching to note taking and marking documents with S Pen easier. Choose from 4 dynamic viewing modes on the 12" Galaxy Book and 3 viewing modes on the 10.6" version.
A refined S Pen
The new in-box S Pen and optimised applications open up a world of possibilities. Boost your productivity and efficiency with enhanced sensitivity, comfortable grip, ultra-precise 0.7mm tip and battery-free operation.
Maximised power
Powerful enough to last even longer so you get everything done. The Galaxy Book gives you up to11 hours of continuous usage on a full charge, so you can enjoy your content whenever you want it without any disruption
Seamless synchronisation
Move beyond wires for good. Samsung Flow syncs with your SAMSUNG smartphone to receive notifications and transfer data as seamlessly as possible. It even lets you start something on a different device, then pause and pick it up again from the same place on your Galaxy Book.
*Only applies to 12" model
Product Description | Samsung Galaxy Book - 12" - Core i5 7200U - 8 GB RAM - 256 GB SSD | Product Type | Tablet - with detachable keyboard | Operating System | Windows 10 Home | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 8 GB LPDDR3 | Storage | 256 GB SSD | Display | 12" OLED touchscreen 2160 x 1440 / Full HD Plus | Graphics | Intel HD Graphics 620 | Input Device | Touchpad, detachable keyboard, S Pen | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | Up to 11 hours | Features | Accelerometer, ambient light sensor, hall sensor | Colour | Silver, black (keyboard) | Image Colour Disclaimer | The displayed product image may be a different colour | Dimensions (WxDxH) - tablet | 29.13 cm x 19.98 cm x 0.74 cm | Weight | 754 g |
General | |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD |
Display | |
Type | 12" OLED - Super AMOLED |
Touchscreen | Yes |
Resolution | 2160 x 1440 (Full HD Plus) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Colour Support | 16 million colours |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Dynamic Video Memory Technology 5.0 |
Camera | Yes - 4096 x 3072 (rear), 2560 x 1440 (front) |
Resolution | 13 Megapixel (rear), 5 Megapixel (front) |
Image Sensor Type | CMOS |
Video Resolutions | 3840 x 2160 |
Frame Rate | 30 frames per second |
Camera Features | Autofocus, Panorama |
Sound | Stereo speakers |
Input | |
Type | Touchpad, detachable keyboard, S Pen |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Navigation | |
Receiver | GPS/GLONASS |
Battery | |
Capacity | 5070 mAh |
Run Time | Up to 11 hours |
Connections & Expansion | |
Interfaces | 2 x USB-C 3.1 |
Memory Card Reader | Yes (microSDXC) |
Miscellaneous | |
Integrated Options | Accelerometer, ambient light sensor, hall sensor |
Features | MIMO technology, fast charging |
Included Accessories | Power adapter, keyboard, S Pen, keyboard case |
Cables Included | USB-C cable |
Dimensions & Weight | |
Weight | 754 g |
