Samsung Galaxy Note 10+ 5G 512GB - Aura Glow
FREE BUNDLE
LIMITED TIME OFFER
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Impossibly thin design
  • Cinematic display
  • All-day battery lasts as long as you do
  • Engineered for gaming, perfected for gamers
  • Pro-grade camera that turns everyday photos and videos into epic moments
  • Special effects for mobile video
  • Zoom-in mic lets you record the sounds you want
  • Super steady makes action shots smooth and natural
  • Air actions give you intuitive control with a wave of your hand
  • Hyper-fast 5G speeds
  • Operating system: Android
  • Model: Note10+ 5G
  • Screen Size: 6.8in
  • Rear Camera: 16 Megapixel
  • Mobile Connectivity: 5G
Product codes
Bundle deals (4)
SAMSUNG GALAXY BUDS+
= £1,328.00
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £1,313.00
Save £25.00
JUICE 2M USB-C CABLE
= £1,205.98
Save £8.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £1,202.49
Save £1.50
High-polish metal and glass meld seamlessly — all in an impressively slim design.
Cinematic Infinity-O Display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions.
Power to get you through your most demanding days
Our cutting-edge battery ensures your Galaxy Note10+ keeps up with your day.
The multi-camera system takes photography to a whole new level
Galaxy Note10 and Note10+ have all the camera essentials, from the dual aperture lens to the Ultra Wide Camera, Live focus and even Scene Optimiser.
Control your device through clicks and gestures
Air actions let you zoom in or out with the camera, change the volume, or flip through photos and more with a simple wave or click.
The screen you can write on when you need it
Take notes and draw on the screen whenever inspiration strikes without opening an app.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
Promotions (1)
GET A FREE CASE WORTH UP TO £30!
We've teamed up with our partners at CaseStation to give you a FREE case worth up to £30!
Once you've placed your order, complete this form with all the required information.
Product Description Samsung Galaxy Note10+ 5G - aura glow - 5G - 512 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 5G
Manufacturer Model Number SM-N976B
Display OLED display - 3040 x 1440 pixels - 6.8" - 498 ppi - Infinity-O Dynamic AMOLED - HDR
Features Front-facing camera, heart rate sensor, stereo speakers, digital player, quad rear-facing camera
Processor Samsung Exynos 9 9825 / 2.7 GHz (8-core) - 64-bit
Memory 512 GB RAM 12 GB
Supported Memory Card microSDXC slot - up to 1 TB
Operating System Android 9.0 Pie
Rear Camera 16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic
Second Rear Camera 12 Megapixel - telephoto lens - f/1.5 & f/2.4
Third Rear Camera 12 Megapixel - f/2.1
Fourth Rear Camera 0.3 Megapixel - depth camera
Front Camera 10 Megapixel f/2.2 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Single-SIM
Wireless Interface NFC, Bluetooth, ANT+, Wi-Fi
Security Devices Face recognition, fingerprint reader (under display)
Messaging Services SMS, MMS
Connectors USB-C
Talk Time Up to 1680 minutes
Wireless Charging Standards WPC, PMA
Protection Dustproof, splashproof, waterproof
Colour Aura glow
Dimensions (WxDxH) 77.2 mm x 7.9 mm x 162.3 mm
Weight 198 g
SAR 1.404 W/kg (body), 0.187 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy Note 10...
£1,199.00
