Samsung Galaxy Note 9 512GB 6.4" - Frosted Lavender
Key features
  • The phone powerful enough to keep up with you
  • Optimized for gaming
  • Bluetooth enabled and perfect control
  • Intelligent camera
Product codes
Meet the phone made to keep up with you. Our reinvented Bluetooth enabled S Pen allows you to control features remotely up to 10m, while an impressive 128GB of internal storage means you’ll never run out of space. Plus, our most powerful battery yet will keep going as long as you need.
  • Bluetooth enabled S Pen to control features remotely up to 10m
  • 4,000 mAh battery that lasts as long as you need it to
  • Cutting edge processor for super-fast internet
  • 128GB of internal memory means you’ll never run out of room
Rewrite the rules
The redesigned S Pen is unlike any other. Now Bluetooth enabled, use it remotely to take selfies up to 10m away, or as an impressive presentation clicker. And when inspiration strikes, scribble down ideas instantly thanks to the Screen Off Memo feature.
See beyond boundaries
Lose yourself in a large 6.4" Infinity Display with absolutely nothing to interrupt your view. If you’re into movie marathons or boxset binges, this screen was made for you. Plus, it’s easier to multi-task between tabs, split the screen or fully focus on important docs.
Shoot like a pro
The Note9 doesn’t just capture, it sees. The Intelligent Camera detects and adjusts to your surroundings, while Dual Aperture adapts to any lighting. Teamed with Flaw Detection to give you a heads up on blinking or blurring, you’ll shoot perfect pics day or night.
Charge ahead
With a battery that charges faster and lasts longer, the Crown is up for whatever you are. Whether you’ve got back-to-back meetings or you’re heading off on an adventure without a socket in sight, the Crown won’t let you down.
Speed up surfing
The cutting-edge processor is built to thrive off fast internet connections. So you can browse shopping sites, download huge presentations or upload high-resolution videos, all without having to wait around watching spinning wheels.
Store more, delete less
Never have to make those tough deleting decisions again. Thanks to an impressive 128GB of storage, you can keep all the shots, videos and files you want with no worries. You can even top it up with additional 512GB of external memory* to ensure you’ll never be tight for space again.
*External Memory may be used to store media (photos, video and music files) but not applications.
Product Description Samsung Galaxy Note9 - lavender purple - 4G HSPA+ - 512 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-N960F
Display OLED display - 2960 x 1440 pixels - 6.4" - 516 ppi - Quad HD+ Super AMOLED
Features Front-facing camera, heart rate sensor, stereo speakers, dual rear-facing camera, digital player
Processor Samsung Exynos 9 9810 / 2.7 GHz (8-core) - 64-bit
Graphics Accelerator Mali-G72 MP18
Memory 512 GB - RAM 8 GB + microSDHC, microSDXC slot - up to 512 GB
Operating System Android 8.1 Oreo
Rear Camera 12 Megapixel - wide-angle lens - 2x optical zoom - f/1.5 & f/2.4 - focus: automatic
Second Rear Camera 12 Megapixel - telephoto lens - f/2.4
Front Camera 8 Megapixel - wide-angle lens - f/1.7 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Slot Qty Single-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices Fingerprint reader, eye scan, face recognition
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1740 minutes
Wireless Charging Standards WPC, PMA
Protection Dustproof, splashproof, waterproof
Colour Lavender purple
Dimensions (WxDxH) 76.4 mm x 8.8 mm x 161.9 mm
Weight 201 g
SAR 1.509 W/kg (body) / 0.381 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy Note 9...
