Samsung Galaxy S10+ 128GB - Prism Black
FREE DELIVERY
FREE BUNDLE
LIMITED TIME OFFER
Sorry but this product has been discontinued.
View used stock
Colours:
Key features
  • So much screen, so little bezel
  • One UI simplifies the way you use your phone
  • Cinema-grade display you'll have to see to believe
  • Completely redesigned to remove interruptions
  • Power is yours to share
  • Stream and share, wherever life takes you
  • Capture the wider world
  • A smarter camera for better photos
  • EE Unlocked
  • Operating system: Android
  • Model: S10+
  • Screen Size: 6.4in
  • Rear Camera: 12 Megapixel
  • Mobile Connectivity: 4G
Product codes
This is a brand new Samsung Galaxy S10+ Black (SM-G975F). This device was originally locked to the EE network, but has now been unlocked to work with other UK networks. The device will come pre-loaded with the MyEE and BT Sport apps, but these can be removed from the device if not needed.
Infinity-O Display is the new, truly uninterrupted view.
We've eliminated distractions for a cinematic viewing experience. By utilising precise laser cutting, the camera has been discreetly tucked away within the display without sacrificing photo quality.
Ultrasonic Fingerprint makes vault-like security totally invisible.
We moved the Fingerprint Scanner from the back to the front, creating a revolutionary, on-screen sensor. Using ultrasonic pulses, it detects the 3D ridges and valleys of your fingerprint, so only you can access your phone. It's secure and convenient — even allowing you to unlock, drag and hold to open the app you want.
Cinematic Display you'll have to see to believe.
The next generation, Dynamic AMOLED screen is HDR10+ certified, delivering Dynamic Tone Mapping for amazingly real color and contrast in each scene — even the dark ones. And the brighter screen helps you see it clearly even in bright daylight. Paired with stereo speakers and Dolby Atmos, the experience is truly immersive.
Eye Comfort Display engineered to adjust to the light for a better view.
A unique fluid composite in Dynamic AMOLED reduces harmful blue light without changing the color of what's on-screen. Watch or play late into the night with less eye strain for a better night's sleep.
Multi-camera with Ultra Wide Camera revolutionises the way you shoot.
It's a full kit of lenses in your pocket. There’s a Telephoto Camera for amazing zoom possibilities, a Wide-angle Camera for everyday moments and an Ultra Wide Camera for panoramic landscapes.
Dual aperture and Multi-frame composition bring out the light in the dark.
You’re ready for photos day or night with dual aperture providing day to night light control — adjusting and optimizing light before you tap the shutter. Plus, the powerful processor automatically combines multiple frames of the same low-light moment into one beautiful shot.
Telephoto, Wide-angle, and Ultra Wide Cameras powerful enough to capture your vision.
The powerful, next gen 16MP Ultra Wide Camera lets you fit more in each shot. And in combination with the 12MP Wide-angle and Telephoto Cameras, you can shoot with 2x optical zoom.
Intelligent battery that keeps you in charge when it matters most.
The Galaxy S10e, S10 and S10+ learn your daily routine and usage patterns, powering down apps you don't need. Also, Adaptive Power Saving Mode manages your battery life based on the prediction of your day. And with up to a 4100mAh (typical) battery capacity on the Galaxy S10+, you can spend more time living and less time charging.
Water and dust resistant to withstand the elements.
Worry less about your phone, regardless of the environment. The Galaxy S10e, S10 and S10+ feature an IP68 rating, the highest mobile device standard for water and dust resistance.
EE unlocked
We have not tested that this device will work across every UK network operator.
There is no requirement for you to use this device on the BT/EE network.
Promotions (1)
GET A FREE CASE WORTH UP TO £30!
We've teamed up with our partners at CaseStation to give you a FREE case worth up to £30!
Once you've placed your order, complete this form with all the required information.
Product Description Samsung Galaxy S10+ - prism black - 4G - 128 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G975F/DS
Display OLED display - 3040 x 1440 pixels - 6.4" - 522 ppi - 19:9 - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Features Stereo speakers, digital player
Processor Exynos 2.7 GHz (8-core) - 64-bit
Memory 128 GB RAM 8 GB
Supported Memory Card microSDXC slot - up to 512 GB
Operating System Android 9.0 Pie with One UI
Rear Camera 12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Rear Camera 16 Megapixel - ultra wide-angle lens - f/2.2
Third Rear Camera 12 Megapixel - wide-angle lens - f/1.5 and f/2.4
Front Camera 10 Megapixel - wide-angle lens - f/1.9 - automatic
Second Front Camera 8 Megapixel - capture depth information
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Dual-SIM
Wireless Interface NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices Face recognition, fingerprint reader (under display)
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1500 minutes
Wireless Charging Standards WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection Dustproof, splashproof, waterproof
Colour Prism black
Dimensions (WxDxH) 74.1 mm x 7.8 mm x 157.6 mm
Weight 175 g
SAR 1.582 W/kg (body), 0.516 W/kg (head)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer. Please Note: There are some fine scratches on the screen.
Ref: FSPJ 042496
£453.28
product
Ref: FSPJ 042496
Accessories
Packaging
Functional
Software
Manuals
£453.28
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
