Samsung Galaxy S10 512GB - Prism White
FREE DELIVERY
FREE BUNDLE
LIMITED TIME OFFER
£949.00
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • So much screen, so little bezel
  • One UI simplifies the way you use your phone
  • Cinema-grade display you'll have to see to believe
  • Completely redesigned to remove interruptions
  • Power is yours to share
  • Stream and share, wherever life takes you
  • A total game changer
  • Capture the wider world
  • A smarter camera for better photos
  • Daily rituals, elevated
  • Operating system: Android
  • Model: S10
  • Screen Size: 6.1in
  • Rear Camera: 12 Megapixel
  • Mobile Connectivity: 4G
Product codes
Bundle deals (4)
PROTECT YOUR DEVICE FROM ‘MINUTE ONE’
= £964.00
Save £10.00
PROTECT YOUR DEVICE WITH OUR PREMIUM ZAGG AND OTTERBOX BUNDLE
= £979.00
Save £10.00
CHARGE YOUR PHONE WIRELESSLY!
= £958.98
Save £5.00
CHARGE 3 DEVICES AT ONCE WITH TRIPLE JUICE!
= £963.98
Save £5.00
The Galaxy S10 features a large curved-edge screen and puts vault-like security at your fingertips with our new Ultrasonic Fingerprint Scanner. With a front camera and 3 rear cameras featuring an ultra-wide and zoom lens, the Galaxy S10 lets you capture every angle of a scene. It also comes with a battery with so much power you’ll be able to share it with your friends.
Discover an endlessly beautiful screen
Enjoy uninterrupted viewing on the Galaxy S10. The stunning 6.1-inch Infinity-O Display is crafted from flawless glass which wraps from edge to edge, with no home button, no notch for the receiver and a simple dot opening for the front camera.
The superpower to share your power
Introducing PowerShare. Bring your friend’s phone back to life if it’s drained. Stack your Galaxy Watch on top of your Galaxy S10 and charge them at the same time. Or top up your Galaxy Buds when you’re on the move.
Capture every moment as you see it
Capture moments as you see them. With a front camera, 3 rear cameras and the ultra-wide and ultra-zoom lens, the Galaxy S10 lets you shoot every scene just as your eyes see it, even in low light.
Bring video to life
Capture incredible 4K UHD videos with a front-facing camera for the first time on a Samsung Galaxy phone. Achieve super steady footage with the Galaxy S10’s ultra-wide rear camera and intelligent software for smooth filming, even when your journey is on the adventurous side.
Vault like security at your fingertips
Keep your phone secure with the new Ultrasonic Fingerprint Scanner. It reads every ridge and notch of your finger, and because it sits under the screen, your finger won’t accidentally smudge your rear camera ever again. It even performs in low temperatures and strong sunlight.
Designed around you
See only what you need, find focus in what you’re doing and use your phone in a way that feels like second nature. Our new interface, One UI, works with the way you use your phone. Screens are uncluttered, icons pop with colour, and we’ve even made it easier to use one-handed.
Charge when it matters most
Go further and do more. The Galaxy S10 has a battery that will keep you in charge when it matters most. Binge on boxsets or flick through playlists with plenty of power to keep up. And with Wireless Charging 2.0, simply pop your phone on the charging pad (sold separately) for a quick power boost.
Make tasks quicker and smoother
Open apps fast and see the detail in every game you play. The processer in the Galaxy S10 is built to perform and makes tasks quicker and smoother.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Promotions
We've teamed up with our partners at CaseStation to give you a FREE case worth up to £30. If you buy an eligible smartphone from BT Shop between 7th February - 29th February 2020, you can claim a voucher code for a FREE case. Once you've received your order, complete this form: https://shop.bt.com/forms/free-case-promotion/
Product Description Samsung Galaxy S10 - prism white - 4G - 512 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G973F/DS
Display OLED display - 3040 x 1440 pixels - 6.1" - 550 ppi - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Features Front-facing camera, heart rate sensor, stereo speakers, digital player, triple rear-facing camera
Processor 2.7 GHz (8-core) - 64-bit
Memory 512 GB - RAM 8 GB
Supported Memory Card microSDXC slot - up to 512 GB
Operating System Android 9.0 Pie with One UI
Rear Camera 12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Rear Camera 12 Megapixel - wide-angle lens - f/1.5 & f/2.4
Third Rear Camera 16 Megapixel - ultra wide-angle lens - f/2.2
Front Camera 10 Megapixel - wide-angle lens - f/1.9 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Dual-SIM
Wireless Interface NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices Face recognition, fingerprint reader (under display)
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1260 minutes
Wireless Charging Standards WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection Dustproof, splashproof, waterproof
Colour Prism white
Dimensions (WxDxH) 70.4 mm x 7.8 mm x 149.9 mm
Weight 157 g
SAR 1.593 W/kg (body) / 0.477 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy S10 512...
£949.00
