Samsung Galaxy S10e 128GB - Prism White
FREE DELIVERY
FREE BUNDLE
LIMITED TIME OFFER
£669.00
Colours:
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • So much screen, so little bezel
  • One UI simplifies the way you use your phone
  • Cinema-grade display you'll have to see to believe
  • Completely redesigned to remove interruptions
  • Power is yours to share
  • Stream and share, wherever life takes you
  • A total game changer
  • Capture the wider world
  • A smarter camera for better photos
  • Daily rituals, elevated
  • Operating system: Android
  • Model: S10e
  • Screen Size: 5.8in
  • Rear Camera: 12 Megapixel
  • Mobile Connectivity: 4G
Product codes
Bundle deals (4)
PROTECT YOUR DEVICE FROM 'MINUTE ONE'
= £684.00
Save £10.00
PROTECT YOUR DEVICE WITH OUR PREMIUM ZAGG AND OTTERBOX BUNDLE
= £699.00
Save £10.00
CHARGE YOUR PHONE WIRELESSLY!
= £678.98
Save £5.00
CHARGE 3 DEVICES AT ONCE WITH TRIPLE JUICE!
= £683.98
Save £5.00
Galaxy S10e
The Galaxy S10e features everything you expect from an S series, while fitting perfectly into your life. It packs all of Samsung's latest technology into a convenient and compact design that makes a difference to you. It's flat screen is endlessly beautiful, it let's you capture every moment and gives you the superpower to share your power.
Infinity-O Display
Discover the endlessly beautiful design of the stunning edge-to-edge display.
Wireless Power Sharing
Seamlessly share power between wirelessly chargeable devices.
True Vision Camera
Capture moments as your eyes see them with multiple cameras and an ultra-wide lens.
Side Fingerprint Scanner
Experience vault-like security with our fingerprint scanner.
One UI
Designed around the way you use your phone to make everything effotless.
Get more out of your phone and stay in charge with a powerful battery.
Stream, multitask and game with a high-performing processor.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Promotions
We've teamed up with our partners at CaseStation to give you a FREE case worth up to £30. If you buy an eligible smartphone from BT Shop between 7th February - 29th February 2020, you can claim a voucher code for a FREE case. Once you've received your order, complete this form: https://shop.bt.com/forms/free-case-promotion/
Product Description Samsung Galaxy S10e - white prism - 4G - 128 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G970F/DS
Display OLED display - 2280 x 1080 pixels - 5.8" - 438 ppi - Infinity-O Dynamic AMOLED - HDR
Features Stereo speakers, dual rear-facing camera, digital player
Processor Samsung Exynos 2.7 GHz (8-core) - 64-bit
Memory 128 GB - RAM 6 GB
Supported Memory Card microSDXC slot - up to 512 GB
Operating System Android 9.0 Pie
Rear Camera 12 Megapixel - wide-angle lens - f/1.5 & f/2.4 - focus: automatic
Second Rear Camera 16 Megapixel - ultra wide-angle lens - f/2.2
Front Camera 10 Megapixel - wide-angle lens - f/1.9 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Dual-SIM
Wireless Interface NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices Fingerprint reader, face recognition
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1140 minutes
Wireless Charging Standards WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection Dustproof, waterproof
Colour White prism
Dimensions (WxDxH) 69.9 mm x 7.9 mm x 142.2 mm
Weight 150 g
SAR 1.575 W/kg (body) / 0.582 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy S10e 12...
£669.00
