Samsung Galaxy S8 64GB Black - Premium Pre-Owned
FREE BUNDLE
LIMITED TIME OFFER
£279.00
Delivery:
Key features
  • Selfies done right with Smart Auto Focus
  • Face recognition: open with your face
  • Iris scanner: open with your eyes
  • Fingerprint scanner: open with a touch
  • Water and dust resistance: rain or shine, it works
  • 12 Month Warranty
Product codes
Premium Pre-Owned Samsung Galaxy
Same Phone. Superb Quality. Smart choice.
Warranty
This device includes a 12-month warranty. Details can be found on the warranty card included in the box.
Premium Quality
Fully Retail Packaged
Only certified parts used
Premium ‘as good as new' quality
12 month warranty
Data wiping to MOD standards
Includes approved USB cable
Galaxy S8
The revolutionary design of the Galaxy S8 begins from the inside out. Samsung rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. And it's easy to hold in one hand.
The Infinity Display has an incredible end-to-end screen that spills over the phone's sides, forming a completely smooth, continuous surface with no bumps or angles. It's pure, pristine, uninterrupted glass. And it takes up the entire front of the phone, flowing seamlessly into the aluminum shell. The result is a beautifully curved, perfectly symmetrical, singular object.
The stars aligned for that picture-perfect moment and with the Galaxy S8 camera, that moment is yours to keep. It uses enhanced image processing, taking multiple shots and combining them into one high-quality photo. All you have to do is press the shutter.
You're able to use your Galaxy S8 for longer with each charge because the better-performing processor means a more efficient use of battery life. And with wireless charging and fast charging capabilities, charging the battery is also easy and convenient.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Promotions (1)
GET A FREE CASE WORTH UP TO £30!
We've teamed up with our partners at CaseStation to give you a FREE case worth up to £30!
Once you've placed your order, complete this form with all the required information.
Product Description Samsung Galaxy S8 - midnight black - 4G - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G950F
Display OLED display - 2960 x 1440 pixels - 5.8" - 570 ppi - Quad HD+ Super AMOLED
Features Rear-facing camera, front-facing camera, heart rate sensor
Processor Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
Graphics Accelerator Mali-G71 MP20
Memory 64 GB RAM 4 GB
Supported Memory Card microSDXC slot - up to 256 GB
Operating System Android 7.0 Nougat
Rear Camera 12 Megapixel - f/1.7 - focus: automatic
Front Camera 8 Megapixel f/1.7 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Single-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices Fingerprint reader, eye scan
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1200 minutes
Standby Time Up to 81.12 hours
Protection Water-resistant
Colour Midnight black
Dimensions (WxDxH) 68.1 mm x 8 mm x 148.9 mm
Weight 155 g
SAR 1.27 W/kg (body) / 0.315 W/kg (head)
Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy S8 64GB...
£279.00
