Samsung Galaxy S8 Midnight Black
FREE DELIVERY
£599.98
Colours:
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Infinity display - beyond the bezel
  • Iris scan
  • Three hassle-free ways to unlock your phone
  • World's First 10nm AP - a new standard for better-performing phones
  • Water and dust resistance - rain or shine, it works
  • Battery - power that lasts
  • Wireless Charging - wires be gone
Product codes
Bundle deals (1)
SAMSUNG 64GB EVO PLUS MICROSD
= £607.98
Save £6.98
Unbox Your Phone!
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8 begins from the inside out. Samsung rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size. And it's easy to hold in one hand. Immerse yourself in a bigger view that still fits comfortably in your hand. Galaxy S8 break free from the confines of bezels, offering a smooth, uninterrupted surface that flows seamlessly over the edges. To do this, Samsung completely redesigned the phone from the inside out and also embedded the home button under the screen, where it stays hidden until you need it. So you get a bigger, unobstructed view without a larger phone.
Box Contains
  • Samsung S8 Midnight Black
  • USB Cable
  • Earphone
  • Ejection pin
  • USB power adaptor
  • USB Connector (USB Type-C)
  • Micro USB Connector
Product Description Samsung Galaxy S8 - midnight black - 4G - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G950F
Display OLED display - 2960 x 1440 pixels - 5.8" - 570 ppi - Quad HD+ Super AMOLED
Features Rear-facing camera, front-facing camera, heart rate sensor
Processor Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
Graphics Accelerator Mali-G71 MP20
Memory 64 GB - RAM 4 GB + microSDXC slot - up to 256 GB
Operating System Android 7.0 Nougat
Rear Camera 12 Megapixel - f/1.7 - focus: automatic
Front Camera 8 Megapixel f/1.7 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Slot Qty Single-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices Fingerprint reader, eye scan
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1200 minutes
Standby Time Up to 81.12 hours
Protection Water-resistant
Colour Midnight black
Dimensions (WxDxH) 68.1 mm x 8 mm x 148.9 mm
Weight 155 g
SAR 1.27 W/kg (body) / 0.315 W/kg (head)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CTLR 040276
£550.60
product
Ref: CTLR 040276
Accessories
Packaging
Functional
Software
Manuals
£550.60
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy S8 Midn...
£599.98
