Unbox Your Phone!
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8 begins from the inside out. Samsung rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size. And it's easy to hold in one hand. Immerse yourself in a bigger view that still fits comfortably in your hand. Galaxy S8 break free from the confines of bezels, offering a smooth, uninterrupted surface that flows seamlessly over the edges. To do this, Samsung completely redesigned the phone from the inside out and also embedded the home button under the screen, where it stays hidden until you need it. So you get a bigger, unobstructed view without a larger phone.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Product Description | Samsung Galaxy S8 - orchid grey - 4G - 64 GB - TD-SCDMA / UMTS / GSM - smartphone | Product Type | Smartphone 4G | Manufacturer Model Number | SM-G950F | Display | OLED display - 2960 x 1440 pixels - 5.8" - 570 ppi - Quad HD+ Super AMOLED | Features | Rear-facing camera, front-facing camera, heart rate sensor | Processor | Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit | Graphics Accelerator | Mali-G71 MP20 | Memory | 64 GB - RAM 4 GB + microSDXC slot - up to 256 GB | Operating System | Android 7.0 Nougat | Rear Camera | 12 Megapixel - f/1.7 - focus: automatic | Front Camera | 8 Megapixel f/1.7 - automatic | Service Provider | Not specified | SIM Card Type | Nano SIM | SIM Card Qty | Single-SIM | Wireless Interface | NFC, Wi-Fi, Bluetooth, ANT+/ANT | Security Devices | Fingerprint reader, eye scan | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Talk Time | Up to 1200 minutes | Standby Time | Up to 81.12 hours | Protection | Water-resistant | Colour | Orchid grey | Dimensions (WxDxH) | 68.1 mm x 8 mm x 148.9 mm | Weight | 155 g | SAR | 1.27 W/kg (body) / 0.315 W/kg (head) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | Rear-facing camera, front-facing camera, audio player, voice recorder, heart rate sensor, navigation |
Width | 68.1 mm |
Depth | 8 mm |
Height | 148.9 mm |
Weight | 155 g |
Body Colour | Orchid grey |
SAR Value | 1.27 W/kg (body) / 0.315 W/kg (head) |
Cellular | |
Technology | TD-SCDMA / WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Bixby |
Navigation | GPS, GLONASS, BeiDou, Galileo |
Payment Technology | Samsung Pay |
Input Device | Multi-touch, capacitive |
Messaging & Internet | |
Supported Social Networks and Blogs | Yes |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE |
2G Band | GSM 850/900/1800/1900 / TD-SCDMA |
3G UMTS Band | Band 1, Band 2, Band 4, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 1700, 850, 900 |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT |
Bluetooth Profiles | HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP, BLE |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor |
Additional Features | Face Unlock, Samsung KNOX |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, RTTTL, RTX, OTA, DFF, MID |
Supported Digital Video Standards | MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM |
Processor | |
Type | Samsung Exynos |
Processor Number | 8895 |
Clock Speed | 2.3 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Graphics System | |
Memory | |
RAM | 4 GB - LPDDR4 SDRAM |
Internal Memory Capacity | 64 GB |
User Memory | 52.3 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Sensor Size | 1/3.6" |
Lens Aperture | F/1.7 |
Focus Adjustment | Automatic |
Camera Modes | Slow motion video, Virtual Shot |
Rear Camera | |
Sensor Resolution | 12 Megapixel |
Sensor Size | 1/2.55" |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Digital Zoom | 8 |
Self-Timer Delay | Yes |
Special Effects | Motion effect, HDR, Stamp, Bokeh effect, Grid Line, Stickers |
Camera Modes | Panorama, Slow motion mode, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Food mode |
Light Source | Dual LED flash |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps |
Features | Quick Launch, Tracking Focus, Dual Pixel technology, voice trigger, geotagging, Continuous Auto Focus (CAF), RAW image capture, VDIS (Video Digital Image Stabilisation) |
Display | |
Type | OLED display |
Technology | Quad HD+ Super AMOLED |
Diagonal Size | 5.8" |
Display Resolution | 2960 x 1440 pixels |
Pixel Density | 570 ppi |
Colour Depth | 16.7 million colours |
Features | Always-on display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 3000 mAh |
Talk Time | 1200 minutes |
Standby Time | 81.12 hours |
Run Time Details | Talk: up to 1200 min , Active online usage (Wi-Fi): up to 14 hrs , Active online usage (3G): up to 11 hrs , Active online usage (LTE): up to 12 hrs , Playback (audio (Always On Display Off)): up to 67 hrs , Playback (audio (Always On Display On)): up to 44 hrs , Playback (video): up to 16 hrs |
Miscellaneous | |
Compliant Standards | IP68 |
Included Accessories | Stereo headset, USB cable, power adapter, SIM card removal tool, micro-USB connector, USB-C to Micro-USB Adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Max Depth of Water Resistance | 1.5 m |
