Samsung Galaxy S8 Orchid Grey
Colours:
Key features
  • Infinity display - beyond the bezel
  • Iris scan
  • Three hassle-free ways to unlock your phone
  • World's First 10nm AP - a new standard for better-performing phones
  • Water and dust resistance - rain or shine, it works
  • Battery - power that lasts
  • Wireless Charging - wires be gone
Product codes
Unbox Your Phone!
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8 begins from the inside out. Samsung rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size. And it's easy to hold in one hand. Immerse yourself in a bigger view that still fits comfortably in your hand. Galaxy S8 break free from the confines of bezels, offering a smooth, uninterrupted surface that flows seamlessly over the edges. To do this, Samsung completely redesigned the phone from the inside out and also embedded the home button under the screen, where it stays hidden until you need it. So you get a bigger, unobstructed view without a larger phone.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Product Description Samsung Galaxy S8 - orchid grey - 4G - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number SM-G950F
Display OLED display - 2960 x 1440 pixels - 5.8" - 570 ppi - Quad HD+ Super AMOLED
Features Rear-facing camera, front-facing camera, heart rate sensor
Processor Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
Graphics Accelerator Mali-G71 MP20
Memory 64 GB RAM 4 GB
Supported Memory Card microSDXC slot - up to 256 GB
Operating System Android 7.0 Nougat
Rear Camera 12 Megapixel - f/1.7 - focus: automatic
Front Camera 8 Megapixel f/1.7 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Qty Single-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices Fingerprint reader, eye scan
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, USB-C
Talk Time Up to 1200 minutes
Standby Time Up to 81.12 hours
Protection Water-resistant
Colour Orchid grey
Dimensions (WxDxH) 68.1 mm x 8 mm x 148.9 mm
Weight 155 g
SAR 1.27 W/kg (body) / 0.315 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy S8 Orch...
