Samsung Galaxy Tab S4 WiFi - Grey
LIMITED TIME OFFER
CASHBACK
£509.00
Colours:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Transform your tablet into a PC
  • Pen provided, imagination unlocked
  • At your command
  • Crisp, clear, captivating
  • Truly cinematic surround sound
  • Operating System: Android
  • Processor: Snapdragon 835
  • Screen Size: 10.5in
  • RAM: 4GB
  • Capacity: 64GB
Product codes
Explore, work and watch your favorite shows on a clear and stunningly brilliant screen. Transform your Galaxy Tab S4 into the PC experience with the taskbar you're used to with the DeX. Create a PowerPoint presentation and revise budgets in Excel at your favorite café. Then edit, sketch and capture inspiration with the included S Pen. And using far field mics, you can even control your Tab S4 from a distance with Google Assistant.
Promotions
Claim up to £100 cashback on selected Samsung products, plus £25 CASHBACK BOOST when you buy more than one!
Valid from 19.02.20 - 31.03.20. Click here to claim once you have purchased your products.
Product Description Samsung Galaxy Tab S4 - tablet - Android 8.0 (Oreo) - 64 GB - 10.5"
Product Type Tablet
Operating System Android 8.1 (Oreo)
Display 10.5" Super AMOLED - 2560 x 1600 (287 ppi) - Multi-Touch
Processor QUALCOMM Snapdragon 835 MSM8998 (8-core) - 64-bit
Processor Clock Speed 2.35 GHz
Storage 64 GB
RAM 4 GB
Total User Available Memory 50.8 GB
Supported Flash Memory Cards microSD, microSDHC, microSDXC
Wireless Connectivity 802.11a/b/g/n/ac, Bluetooth 5.0
Camera 13 Megapixel (rear), 8 Megapixel (front)
HD Video Recording 4K
Navigation System GPS/GLONASS/Galileo/BeiDou
Security Devices Eye scan
Features USB Type C, 3.5mm earphone jack
Dimensions (WxDxH) 16.43 cm x 0.71 cm x 24.93 cm
Weight 482 g
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy Tab S4...
£509.00
