Samsung Galaxy Tab S6 Keyboard Book Cover
£119.00
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • A desktop experience one shortcut away
  • PC-like experience
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bundle deals (2)
SAMSUNG GALAXY BUDS+
= £248.00
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £233.00
Save £5.00
Power your portable workstation
Slip the Keyboard Cover on magnetically and begin a PC-like experience in a flash. Use it the way you want with function keys and a touchpad to get to work, or detach just the keyboard when it's not time to type. An embedded holder keeps your S Pen nearby for notes and revisions.
Product Description Samsung Book Cover Keyboard EF-DT860 - keyboard and folio case - with touchpad - grey
Device Type Keyboard and folio case
Interface POGO pin
Input Device Keyboard
Connectivity Technology Wired
Built-in Devices Touchpad
Keys Qty 65
Colour Grey
Dimensions (WxDxH) 24.51 cm x 0.68 cm x 17.87 cm
Weight 359 g
Manufacturer Warranty 1-year warranty
Designed For Galaxy Tab S6
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use. PLEASE NOTE. This is not in the Original packaging but is in a Padded Envelope
Ref: FCHY 042801
£82.38
product
Ref: FCHY 042801
Accessories
Packaging
Functional
Software
Manuals
£82.38
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy Tab S6...
£119.00
