Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
Galaxy Tab S8 Ultra
The new epic standard for tablets
More than just space. The largest Samsung Galaxy Tab S is designed so you can create like a pro. Shoot with our first ultra wide front camera in a tablet and edit on the largest screen in the Samsung Galaxy Tab S. Get it all in a graphite finish that goes with everything.
S Pen
No matter which tablet size you select, the brand new S Pen comes included and magnetically snaps to the back of Galaxy Tab S8 Series to charge.
Write, sketch, doodle or draw all your wildest ideas into reality with the S Pen ultra-low latency. A thousand tools in one, the new S Pen gives you impressive levels of control.
Be the centre of attention, wherever you are
The Dual Front Camera (Ultra Wide + Wide) boasts an impressive field of view that provides optimal 4K video recording.
Divide your screen. Conquer your day
Size. Position. And number of windows. You're in charge with Multi Window. That means you can research decor inspirations, sketch out architectural plans and video chat with your friend — all at once.
5G keeps you streaming on the go
HyperFast 5G delivers the power to keep you streaming whatever you want — music, movies or content. Stream wherever — even outdoors and on the go.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy Tab S8 Ultra - tablet - Android - 128 GB - 14.6" - 3G, 4G, 5G | Product Type | Tablet | Operating System | Android | Display | 14.6" Super AMOLED - 2960 x 1848 - Multi-Touch | Processor | Qualcomm Snapdragon 8 Gen 1 SM8450 (8-core) | Processor Clock Speed | 2.99 GHz | Storage | 128 GB | RAM | 8 GB | User Available Memory | Flash: 101 GB | Supported Flash Memory Cards | microSD, microSDHC, microSDXC | Cellular Technology | 3G, 4G, 5G | Cellular Protocols | GSM, UMTS, FDD LTE, TDD LTE | Wireless Connectivity | Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E) | Rear Camera | 13 Megapixel focus: automatic | Second Rear Camera | 6 Megapixel | Front Camera | 12 Megapixel | Second Front Camera | 12 Megapixel | Navigation System | GPS/GLONASS/Galileo/BeiDou/QZSS | Security Devices | Fingerprint reader | Battery Run Time | Up to 14 hours | Dimensions (WxDxH) | 20.86 cm x 0.55 cm x 32.64 cm | Weight | 728 g | Colour | Graphite | SAR | 0.689 W/kg (body), 0.689 W/kg (limb) |
General | |
Display | |
Type | 14.6" Super AMOLED |
Resolution | 2960 x 1848 |
Colour Depth | 16 million colours |
Touchscreen | Multi-Touch |
Features | 120 Hz refresh rate |
Processor | |
Processor | Qualcomm Snapdragon 8 Gen 1 SM8450 |
Number of Cores | 8-core |
Memory | |
Storage | 128 GB |
RAM | 8 GB |
Max Supported Capacity | 1 TB |
Communications | |
Band | GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B20/B25/B26/B28/B32/B66/B38/B40/B41 / 5G N1/N3/N5/N7/N8/N20/N28/N66/N38/N40/N41/N77/N78 |
Security Protocols & Features | Wi-Fi Direct |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP) |
Rear Camera | |
Sensor Resolution | 13 Megapixel |
Focus Adjustment | Automatic |
Light Source | Flash |
Video Resolutions | 3840 x 2160 (4K UHD) at 30 fps |
Second Rear Camera | |
Sensor Resolution | 6 Megapixel |
Front Camera | |
Sensor Resolution | 12 Megapixel |
Lens Type | Ultra wide-angle lens |
Video Resolutions | 3840 x 2160 (4K UHD) |
Features | Auto framing |
Second Front Camera | |
Features | Wide-angle lens |
Navigation System | |
Receiver | GPS/GLONASS/Galileo/BeiDou/QZSS |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID, Dolby Atmos |
Supported Digital Video Standards | MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM |
Audio | 3 microphones, four speakers |
Input Device | |
Type | S Pen |
Software | |
Preloaded Software | Samsung Smart Switch |
Expansion and Connectivity | |
Expansion Slots | 1 x microSDXC |
Interfaces | 1 x USB-C 3.2 Gen 1 |
Battery | |
Capacity | 11200 mAh |
Talk Time | 3780 min |
Run Time Details | Web browsing over Wi-Fi: up to 8 hour(s) , Video playback: up to 14 hour(s) , Audio playback: up to 148 hour(s) , Web browsing over 4G: up to 8 hour(s) , Talk time: up to 63 hour(s) |
Miscellaneous | |
Colour | Graphite |
Case Material | Reinforced aluminium |
Sensors | Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor |
Features | MIMO technology, Drop Protection, tuned by AKG speakers, Samsung DeX, 4nm processor, 45W ultra fast charging |
SAR Value | 0.689 W/kg (body), 0.689 W/kg (limb) |
Dimensions & Weight | |
Width | 20.86 cm |
Depth | 0.55 cm |
Height | 32.64 cm |
Weight | 728 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
