Samsung Galaxy UK Mains Charger with USB Cable - 2 Amp - White
£35.47
Delivery:
Key features
  • Fast charge
  • Perfect for world traveler
  • Product Range: Samsung Travel Adapter
  • Product Model: EP-TA20U
  • Stock Status:
    Used stock also available below
Product codes
Samsung Travel Power Adapter EP-TA20U (AC / USB - 2000 mA (USB (power only)) - White
Don’t risk running out of power when you need your mobile the most. The portable design of the Samsung Flat TA Charger allows you to keep it handy while at home or at the office. Always be sure that your Samsung Galaxy or other micro USB compatible Device is always fully charged and ready to go.
Includes micro-USB cable
Product Description Samsung Travel Adapter EP-TA20U power adapter
Product Type Power adapter
Dimensions (WxDxH) 4.915 cm x 6.865 cm x 2.8 cm
Weight 55.5 g
Colour White
Output Connector Type USB
Voltage Provided 5 V
Cables USB cable
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: BKN2 042665
£13.42
product
Customer return - item has been opened but is in excellent condition
Ref: BKN2 042673
£13.74
product
Ref: BKN2 042683
£15.61
product
Ref: BKN2 042665
Accessories
Packaging
Functional
Software
Manuals
£13.42
product
Ref: BKN2 042673
Accessories
Packaging
Functional
Software
Manuals
£13.74
product
Ref: BKN2 042683
Accessories
Packaging
Functional
Software
Manuals
£15.61
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Galaxy UK Main...
£35.47
