Samsung Galaxy Z Flip4 128GB - Bora Purple
FREE DELIVERY
39 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Fits all your fits
  • Holds up from flex to flat
  • Flippin' strong
  • Still unafraid of water
  • Live your best nightlife
  • Go ahead, flex on them
  • Operating system: Android
  • Model: Z Flip4
  • Mobile Connectivity: 5G
  • Screen Size: 6.7in
  • Rear Camera: 12 Megapixel
Product codes
Fits all your fits
The era of planning looks around your phone is over. Small but mighty when folded, Galaxy Z Flip4 is a compact full-sized smartphone, and just the right size to slip in a pocket when it's time to slay.
The 6.7-inch display unfolds a beautiful view thanks to Ultra Thin Glass. Advanced durability makes it stronger than ever — staying tough through up to 200,000 folds.
Flippin' strong
From the inside out, Galaxy Z Flip4 is made to be durable. These are our toughest foldables ever with exclusive Corning® Gorilla® Glass Victus®+. And the hinge is protected by Armor Aluminum — our toughest aluminum frame.
Water you worried about? These are the world’s first water-resistant foldable smartphones. It can hang out in 1.5 meters of water for up to 30 minutes without breaking a sweat.
MULTI-CAMERA SYSTEM
The night just got brighter with Nightography on the Rear Camera. Details are brought to light even in the dark with bigger pixels on the Wide Camera. Say cheese!
Nightography isn't just for stills — it's also got video skills. When the action gets going, recordings stay smooth, not shaky, with enhanced OIS and VDIS. Powerful processing allows Super Night Solution to minimise noise so clips of the crew stay clear well into the night.
12MP Ultra Wide Camera
12MP Wide Camera
10MP Selfie Camera
Introducing FlexCam, a versatile, hands-free camera experience. Take advantage of your phone’s agile angles to capture group shots, selfies and videos from mind-blowing perspectives and impressive true-to-life detail — even in your go-to social apps.
Enter your self-portrait era
Take selfies with the Rear Camera while the Cover Screen gives you a real-time preview. Check yourself from afar with a full-screen view finder, or tap to see the original ratio to make sure everyone is in frame. And with new software upgrades, Quick Shot is ready for even more action at all the angles between folded and FlexCam.
Power to the pocket
With this much juice, you can let every call go into overtime. An upgraded 4nm processor works with the long-lasting 3700mAh (typical) battery to power through the hours.
When it's low, plug in for Super Fast Charging or bypass the cord with Fast Wireless Charging 2.0. With all that power to spare, you can even share a charge with your friend or your earbuds with Wireless PowerShare.
Put your style on display
With a customisable 1.9-inch Cover Screen, you get yet another canvas to play with. Change it up as much as you want using your videos, photos or your own AR emoji to personalise the clock face. With this much control, you can easily update it with your mood, the weather or to match your outfits.
Promotions (1)
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description Samsung Galaxy Z Flip4 - bora purple - 5G smartphone - 128 GB - GSM
Product Type 5G smartphone
Manufacturer Model Number SM-F721B
Display OLED display - 2640 x 1080 pixels - 6.7" - 425 ppi - (120 Hz) - Dynamic AMOLED 2X - HDR - Samsung Ultra Thin Glass - inward - foldable
Display (2nd) OLED display - colour - 1.9"
Display (Unfolded) 6.7 in - 2640 x 1080 pixels
Processor 3.18 GHz (8-core)
Memory RAM 8 GB / 128 GB
Operating System Android 12 with One UI
Main Camera 12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Camera 12 Megapixel - ultra wide-angle lens - f/2.2
Front Camera 10 Megapixel f/2.4 - focus free
Service Provider Not specified
Form Factor Folder (flip) - touch screen, dual screen
SIM Card Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface NFC, Wi-Fi 6, Bluetooth
Security Devices Face recognition, fingerprint reader (side)
Connectors USB-C
Talk Time Up to 2040 minutes
Wireless Charging Standards WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare, Reverse wireless charging
Protection Water-resistant
Colour Bora purple
Dimensions (WxDxH) 71.9 mm x 6.9 mm x 165.2 mm
Weight 187 g
SAR 2.75 W/kg (limb), 1.151 W/kg (head), 1.198 W/kg (body)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition Packaging is damaged however, does not effect use of phone.
Ref: GYNP 046068
£728.37
product
Ref: GYNP 046083
£823.38
product
Ref: GYNP 046091
£833.94
product
Customer return - item has been used and shows signs of use
Ref: GYNP 046112
£918.39
product
Ref: GYNP 046068
Accessories
Packaging
Functional
Software
Manuals
£728.37
product
Ref: GYNP 046083
Accessories
Packaging
Functional
Software
Manuals
£823.38
product
Ref: GYNP 046091
Accessories
Packaging
Functional
Software
Manuals
£833.94
product
Ref: GYNP 046112
Accessories
Packaging
Functional
Software
Manuals
£918.39
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£999.00
