Get motivated to move more, eat better, and live a healthy life. The Gear Sport tracks your fitness and diet, keeping you on the right path to reach your goals. It’s as stylish as it is functional.
Product Description | Samsung Gear Sport SM-R600 - black - smart watch with strap - black - 4 GB | Product Type | Smart watch | Operating System | Tizen OS 3.0 | Storage | 4 GB | Connectivity | Wi-Fi, NFC, Bluetooth | Supported Host Device OS | iOS, Android | Display | Super AMOLED - 1.2" - 360 x 360 pixels | Input | Touch screen, rotating bezel | Tracking Data | Distance, time, speed, calories burned, activity, heart rate, steps taken, swim laps, swim stroke rate | Band | Black - strap - silicone - (L) | Features | Heart rate sensor, navigation, SMS notification, Email notification, automatic exercise recognition, social apps notification, inactivity alert, incoming calls notification | Case Size | 43 mm | Dimensions (WxDxH) | 42.9 mm x 11.6 mm x 46 mm | Weight | 67 g |
General | |
Integrated Components | Heart rate sensor, navigation |
Supported Host Device OS | Android 4.3 (Jelly Bean) or later, iOS 9 or later |
Audio Output | Speaker |
Wearing Style | Watch style |
Clock Display | Yes |
Set Goals | Yes |
Features | SMS notification, Email notification, automatic exercise recognition, social apps notification, inactivity alert, incoming calls notification, accelerometer, ambient light sensor, barometer, altimeter, gyro sensor, heart rate |
Storage | |
Capacity | 4 GB |
Display | |
Type | Super AMOLED - colour |
Resolution | 360 x 360 pixels |
Diagonal Size | 1.2" |
Protection | Corning Gorilla Glass 3 (scratch resistant glass) |
Aspect Ratio | Full circle |
Connectivity | |
Wireless Interface | IEEE 802.11b/g/n, NFC, Bluetooth 4.2 |
Input Device | |
Type | Touch sensitive screen, rotating bezel |
CPU | |
Clock Speed | 1 GHz |
RAM | |
Size | 768 MB |
Battery | |
Capacity | 300 mAh |
Smart Watch Case | |
Case Shape | Round |
Case Size | 43 mm |
Case Details | Black |
Band | |
Name | Strap |
Size | L |
Clasp Type | Buckle |
Width | 20 mm |
Material | Silicone |
Colour | Black |
Dimensions & Weight | |
Width | 42.9 mm |
Depth | 11.6 mm |
Height | 46 mm |
Weight | 67 g |
Miscellaneous | |
Vibrating Alert | Yes |
Protection | Dustproof, waterproof |
Compliant Standards | MIL-STD 810G |
Included Accessories | Power adapter, wireless charging dock, small wrist strap |
Environmental Parameters | |
Max Depth of Water Resistance | 50 m |
