The Sound+ HW-MS750 offers rich, room-filling sound, with an expanded soundstage that adds depth and dimension to your favorite movies and music. With fewer wires and a single mount option, the seamless, one-piece design becomes one with your TV.
Product Description | Samsung Sound+ HW-MS750 - sound bar - for home theatre - wireless | Product Type | Sound bar - for home theatre | Enclosure Design | Sealed | Speaker Type | Active | Frequency Response | 35 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant Compatible | Alexa | Audio Formats | WAV, AAC, MP3, FLAC, OGG, ALAC | Speaker Details | Sound bar 5 | Colour | Black | Built-in Decoders | Dolby Digital, DTS Digital Surround | Sound Effects | Surround Sound Expansion, Smart Sound Mode, Distortion Cancelling technology | Dimensions (WxDxH) | 115 cm x 13.04 cm x 8 cm | Weight | 6.3 kg | Manufacturer Warranty | 1-year warranty |
General | |
Enclosure Colour | Black |
Speaker System | |
Multiroom | Yes |
Multiroom Technology | Samsung Multiroom |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP) |
Transmission Range | 10 m |
Recommended Placing | Wall-mountable, table-top, under-the-TV |
Controls | Input selector, power on/off, volume |
Internet of Things (IoT) | |
Voice Control | Indirect |
Speaker System Details | |
Driver Details | Sound bar: 6 x woofer driver , Sound bar: 5 x tweeter driver |
Connections | |
Connector Type | 2 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , AC power input , AC power loop through |
Miscellaneous | |
Included Accessories | Remote control, power cable, cable holder, screw |
Power | |
Power Source | Integrated power supply |
Power Consumption Operational | 50 Watt |
Dimensions & Weight | |
Width | 115 cm |
Depth | 13.04 cm |
Height | 8 cm |
Weight | 6.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 137.6 cm |
Shipping Depth | 22.6 cm |
Shipping Height | 14.8 cm |
Shipping Weight | 8.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
