Samsung LS32A800NMU 32" 3840x2160 5ms HDMI DP LED Monitor
£385.40
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • UHD resolution with HDR10
  • Adjustable ergonomic stand
  • Sleek 3-sided bezel-less design
  • Diagonal Size: 32in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, DisplayPort
Product codes
UHD resolution Explore and immerse yourself in every detail. With 4x the pixels of Full HD, every detail is viewed in enhanced depth, while more screen real estate provides space to view multiple tools, applications and programs during the day – creating a 4K cinematic content viewing experience night and day.
Automatic Source Switch Your monitor detects newly connected devices as soon they're plugged in, and displays the correct signal. No more searching for the right input on the menu
TUV certified Intelligent Eye Care Keep your eyes fresh and strain-free. For those late-night projects, brightness and colour temperature adjust automatically for optimization in any environment. TUV-certified for intelligent eye care, Samsung protects eyes against excessive blue light with eye saver mode and a flicker free feature.
Position your monitor for optimal comfort Borderless design, VESA mount compatibility and a variety of tilt, swivel and pivot control points allow you to mount your monitor in any environment. In addition, a slim metal stand and narrow depth take up less desk space for a clean, seamless work setup.
Product Description Samsung S32A800NMU - S80A Series - LED monitor - 4K - 32" - HDR
Device Type LED-backlit LCD monitor - 32"
Energy Class Class G
Energy Consumption per Year 54 kWh
Features USB Hub
Panel Type VA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.18159 mm
Brightness 300 cd/m²
Contrast Ratio 2500:1
HDR Capable HDR10
Response Time 5 ms
Colour Support 1.07 billion colours
Colour Gamut 99% sRGB
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 100/240 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 71.61 cm x 21.14 cm x 58.04 cm
Weight 7 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£385.40
