Samsung PRO Endurance 128GB Micro SDXC Flash Memory Card
£35.64
1 due in 3-4 days
Delivery:
  • Type: microSDXC UHS-I Memory Card
  • Capacity: 128GB
  • SD Speed Class: UHS-I U1 / Class10
  • Stock Status: Used Stock
Product codes
Samsung PRO Endurance MB-MJ128GA Flash memory card (microSDXC to SD adapter included) 128 GB - UHS-I U1 / Class10 microSDXC UHS-I
Product Description Samsung PRO Endurance MB-MJ128GA - flash memory card - 128 GB - microSDXC UHS-I
Product Type Flash memory card
Form Factor microSDXC UHS-I Memory Card
Storage Capacity 128 GB
Speed Rating UHS-I U1 / Class10
Included Memory Adapter microSDXC to SD adapter
Manufacturer Warranty 5-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: DRB0 041495
£29.29
product
Ref: DRB0 041495
Accessories
Packaging
Functional
Software
Manuals
£29.29
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung PRO Endurance...
£35.64
