Samsung S19F355H 19" 1366x768 5ms VGA LED Monitor
Select:
Product codes
Featuring a dedicated game mode, the LS19F355 LED Monitor is able to optimise colour and contrast for gaming, so you can enjoy every scene in great quality. Comfortable viewing To reduce fatigue after long gaming sessions, the LS19F355 Monitor has Eye Saver Mode, which reduces blue light emissions for a more comfortable viewing experience. Slim design The Samsung LS19F355 18.5" LED Monitor is incredibly slim at only 10 mm, which is as thin as a ballpoint pen. It looks great on your desk and can also be mounted on the wall - all you need is a standard TV bracke
Product Description Samsung SF355 Series S19F355HNU - SF355 Series - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1366 x 768 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Colour High glossy black
Dimensions (WxDxH) - with stand 44.2 cm x 17.4 cm x 35.54 cm
Weight 2 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S19F355H 19" 1...
