Samsung S22E200B 21.5" 1920x1080 5ms VGA DVI LED Monitor
£89.43
Select:
  • 21.5"
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Environmentally friendly
  • Impressive picture quality
  • Slim design that fits any desk
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £218.43
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £203.43
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £92.92
Save £1.50
Clear picture quality with fast response time
  • Fast 5ms Response Time: See even fast on-screen motion clearly and smoothly with less motion blur, judder or ghosting.
  • Full HD Resolution: Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all of your content clearly.
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy with energy-efficient features
  • SMART Eco Saving: The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen’s black sections while simultaneously adjusting the RGB gain values.
Eco-friendly materials with Intertek Green Leaf certification
  • Recycled Plastics: All Samsung business monitors are made of 30% recycled plastics.
  • PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact.
  • Accessory Packaging: Samsung has reduced the LDPE (Low-Density Polyethylene) in accessory packaging from 100% to 80% by using bio-friendly Sugar cane (20%) as an alternative manufacturing material. Samsung packaging is now Vinçotte-certified.
Optional mountable USB soundbar
  • The ability to access multimedia content on workplace devices is becoming increasingly important for businesses. In order to accommodate this need, the Samsung SE200 can be fitted with an optional USB soundbar. Thanks to a seamless mounting system, the soundbar attaches to the back of the monitor to provide the same benefit as a built-in speaker. This convenient add-on delivers quality sound (2.5 W) while saving space and keeping your workspace more organised.
A professional ergonomic monitor for truly professional needs
  • VESA Support: With support for VESA 100 X 100, you can easily mount it on any wall.
  • Tilt: Easily and smoothly tilt the screen forward 20° and backwards 21° for comfortable viewing.
Product Description Samsung S22E200B - SE200 Series - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.24825 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - with stand 50.43 cm x 17 cm x 38.54 cm
Weight 3.37 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards C-Tick, EN55022, SASO, EN55024, FCC Part 15 B, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S22E200B 21.5"...
£89.43
