Samsung S22E450DW 22" 1680X1050 5ms VGA DVI DP TN LED Mo...
Samsung S22E450DW 22" 1680X1050 5ms VGA DVI DP TN LED Monitor
Key features
  • 22" screen provides excellent visibility and legibility
  • Built from up to 30% recycled plastic, with less than 0.005W off-mode power consumption
  • VESA mount compatibility, VGA, DVI and DisplayPort connections, and speaker bar compatibility
Product codes
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description Samsung S22E450DW - SE450 Series - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Features USB Hub
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 50.24 cm x 21 cm x 38.75 cm
Weight 5.03 kg
Compliant Standards Intertek GS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
