Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Mo...
Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
£128.12
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 16:10 aspect ratio for viewing legacy applications
  • Built from up to 30% recycled plastic, with less than 0.005W off-mode power consumption
  • VESA mount compatibility, VGA and DVI connections, and speaker bar compatibility
Product codes
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. The features of this 19" monitor include a simple and easy to use design, fully adjustable stand, matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description Samsung S22E450F - SE450 Series - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 23 W
Features USB Hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.24825 mm
Brightness 250 cd/m²
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 50.43 cm x 21 cm x 32.53 cm
Weight 4.57 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S22E450F 21.5"...
£128.12
