Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Mo...
Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
£123.19
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • 16:10 aspect ratio for viewing legacy applications
  • Built from up to 30% recycled plastic, with less than 0.005W off-mode power consumption
  • VESA mount compatibility, VGA and DVI connections, and speaker bar compatibility
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. The features of this 19" monitor include a simple and easy to use design, fully adjustable stand, matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description Samsung S22E450F - SE450 Series - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 23 W
Features USB Hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.24825 mm
Brightness 250 cd/m²
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 50.43 cm x 21 cm x 32.53 cm
Weight 4.57 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S22E450F 21.5"...
£123.19
