The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. The features of this 19" monitor include a simple and easy to use design, fully adjustable stand, matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description | Samsung S22E450F - SE450 Series - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class B | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 23 W | Features | USB Hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.24825 mm | Brightness | 250 cd/m² | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 50.43 cm x 21 cm x 32.53 cm | Weight | 4.57 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB Hub |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | Mega Dynamic Contrast Ratio, Flicker Free technology, Smart Energy Saving technology, Eye Saver Mode, Off Timer Plus, 72% (NTSC 1976) colour gamut |
Colour | Black |
Dimensions (WxDxH) | 50.43 cm x 21 cm x 32.53 cm - with stand |
Weight | 4.57 kg |
Connectivity | |
Interfaces | VGA , DVI , HDMI , 2 x USB |
Mechanical | |
Tilt Angle | -3/+25 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | PVC free |
Cables Included | 1 x VGA cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
OS Required | Windows 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.43 cm - depth: 21 cm - height: 32.53 cm - weight: 4.57 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.07 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
