Samsung S22E650D 21.5" 1920x1080 4ms VGA HDMI DP PLS LED...
Samsung S22E650D 21.5" 1920x1080 4ms VGA HDMI DP PLS LED Monitor
Select:
  • 21.5"
Key features
  • Business tool that produces crystal-clear images
  • Monitor designed to match business needs
  • Maximize workspace with the efficient handle VESA wall mount
  • Conveniently adjust monitor height, tilt, and perspective
  • Save energy and see the results with the energy tree
  • Control power consumption, conserve energy
  • Gentle on the eyes and on the environment
  • Save energy with smart motion technology
  • See your work from the best possible angle
Product codes
The Samsung LED Business Monitor SA650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SA650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SA650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SA650 is ready to deliver an efficient and clean work space. The SA650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SA650.
The Samsung LED Business Monitor SA650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA650.
Samsung SE650 Series S22E650D - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
50.43 cm x 21 cm x 35.44 cm
4.87 kg
Environmental Standards
ENERGY STAR Qualified
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S22E650D 21.5"...
