Super slim panel
At an incredibly slim 10mm — as slender as a ballpoint pen — the one-piece panel is more than twice as thin as standard Samsung monitors
Simple circular stand
A simple circular stand elegantly complements the super-slim display
Patterned rear panel
Horizontal patterning on the rear panel provides a stylish, contemporary finish
Product Description | Samsung S22F350FHR - SF35 Series - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class E | Energy Consumption per Year | 23 kWh | Power Consumption (On mode) | 16 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 200 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% (NTSC 1976) | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 50.86 cm x 20.65 cm x 39.54 cm | Weight | 2.8 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Super Slim Design |
Colour | Black |
Dimensions (WxDxH) | 50.86 cm x 20.65 cm x 39.54 cm - with stand |
Weight | 2.8 kg |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
Tilt Angle | -1/+22 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.86 cm - depth: 20.65 cm - height: 39.54 cm - weight: 2.8 kg , Without stand - width: 50.86 cm - depth: 8.01 cm - height: 30.2 cm - weight: 2.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 56.8 cm |
Shipping Depth | 15.3 cm |
Shipping Height | 36.3 cm |
Shipping Weight | 4 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
