Samsung S24A600UCU 24" 2560x1440 5ms HDMI DP USB-C LED M...
£244.03
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Discover the details
  • See greatness from any angle
  • Enjoy a billion colors with incredible depth
  • Relieve your eyes from strain
  • Maximize comfort, minimize distractions
  • Stay in sync with the action
  • Diagonal Size: 24in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, DisplayPort, USB-C
Product codes
Quad HD LED display
See more detail with the Samsung LS24A600UCUXXU Quad HD 24" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
Product Description Samsung S24A600UCU - S60UA Series - LED monitor - 24" - HDR
Device Type LED-backlit LCD monitor - 24"
Energy Class Class F
Power Consumption (On mode) 19 W
Adaptive-Sync Technology AMD FreeSync
Daisy Chaining Yes
Features USB 3.0/USB-C hub, USB PD 65 Watt
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 75 Hz
Brightness 300 cd/m²
Contrast Ratio 1000:1
HDR Capable HDR10
Response Time 5 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/240 V
Colour Black
Dimensions (WxDxH) - with stand 54.23 cm x 19.64 cm x 53.08 cm
Weight 5 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Samsung S24A600UCU 24" 2560x1440 5ms HDMI DP USB-C LED Monitor
£244.03
