Samsung S24D330H 24" 1920x1080 1ms HDMI Monitor
£99.64
Select:
  • 24"
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple, easy-to-use design
  • Exceptional picture quality
  • Optimized for video
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £228.64
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £213.64
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £103.13
Save £1.50
The Samsung LED Monitor SD300 Series does all the work you need in just the right manner. Functional and with a stylish design, this monitor is all you need.
Product Description Samsung S24D330H - SD300 Series - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour High glossy black
Dimensions (WxDxH) - with stand 56.9 cm x 19.7 cm x 41.72 cm
Weight 3.15 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CCXX 042595
£60.18
product
Ref: CCXX 042595
Accessories
Packaging
Functional
Software
Manuals
£60.18
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24D330H 24" 1...
£99.64
