Samsung S24E450BL 23.6" 1920x1080 5ms VGA DVI LED Monitor
£126.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Environmentally friendly
  • Impressive picture quality
  • Slim design that fits any desk
  • Ergonomic, adjustable stand
  • Fast, easy connectivity
  • Diagonal Size: 23.6in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £255.26
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £240.26
Save £25.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £129.75
Save £1.50
The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description Samsung S24E450BL - SE450 Series - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2715 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 55.46 cm x 22.4 cm x 35.23 cm
Weight 5.48 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards TUV, C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24E450BL 23.6...
£126.26
